Touring bike gear c...
[Closed] Touring bike gear choice
 kcal
What's general consensus on touring bike gear ranges?
I assume something like 24-34-44 sort of spread at front - rear - 12 to ? 30/32/34 -
-- any advantage in retaining 8 speed at the back?
Posted : 29/07/2015 8:52 pm
Sort of being done here...
http://singletrackworld.com/forum/topic/proper-touring-bikes-anyone-know-much-about-them
I run a road triple(52/39/30) with an XT 32t cassette
Posted : 29/07/2015 8:53 pm
20" to 100" 'ish' should do you right
Posted : 29/07/2015 9:08 pm
Sora 50/39/24 triple and a 11-32 9 speed cassette here kCal.
The bike came with a 30 tooth granny ring but I had to swap it for something grannier.
Posted : 29/07/2015 9:21 pm
Depends on fitness and where you are riding.
I'd go lower than 30T granny, 24 ideally, then 32t rear. Should be good for 4 panniers in the Alps.
Posted : 29/07/2015 9:28 pm
22/32/44 with 11/32 here. I figure that low gears are good ๐Ÿ™‚
Posted : 29/07/2015 9:29 pm
 kcal
Thanks for t link and numbers, I'm not sure I'd use 50 much on a certain road bike so might go bit lower on a tour oriented machine!!
Posted : 29/07/2015 9:42 pm
38/28 chainrings x 11-40 praxis cassette for me, gives a 19.2" low and a 95" high which is a decent range, I previously had a 11-36 xt cassette 21.4" low gear which i thought was enough but the praxis 40t just makes the hills so much easier thus i enjoy more of the ride.
Posted : 29/07/2015 9:52 pm
Forgot the link doh..
http://www.sheldonbrown.com/gears/internal.html
Good for comparison of current and possible set ups.
Posted : 29/07/2015 9:53 pm
 irc
I'm 22-32-42 and 11-34. Though I'm going to a 12-34 to avoid the 17-20 jump.
Suggest you think how you would gear a 1x? bike. Then go for a triple with the middle that size. So you are then on the middle ring most of the time. You have the granny ring for steeper/longer hills and the big ring for mega tailwinds/long downhills.
Posted : 29/07/2015 10:58 pm
 kcal
Is there any advantage to having 8 speed at the back (or is it a disadvantage these days) ?
Posted : 30/07/2015 7:39 am
I'm running 9 on the tandems and tourers. Easy to get good replacements without losing quality.
It used to be argued 8 lasts longer than 9, 9 longer than 10, 10 longer than 11 etc. I'm not sure how much this holds true between 8 and 9 but on longer tours, availability of parts is also important. I also seem to get similar mileage from 9 speed parts as I did from 8.
Posted : 30/07/2015 7:57 am
