Tour of Liathach
[Closed] Tour of Liathach
I'm looking for new a Torridon route - have done the Ben Damph loop and the Lollipop.
I was thinking of cycling out toward Inveralligin on the road, turning right and climbing up Coire MhicNobaill, down Coire Dubh Mor and then heading back into town on the A896. Is that the acknowleged route?
I've seen it described on here as a "march of doom", which doesn't instill confidence. Aerial pics on Bing Maps suggest that the trail exists and it looks rocky rather than boggy. So what gives?
Cheers,
Neil.
TLDR; What is it, and what's wrong with it?
Posted : 21/04/2015 4:02 pm
I did that loop last year, it isn't terrible but there is a lot of hike a bike over boulders as you approach the highest point, the descent down to the road is quite a good blast and sure gets the old brakes hot anyway. I don't think I would do it again but if the weather is nice there are worse ways to pass a few hours and the scenery is great. We ended the ride at the pub, which is nice.
https://www.strava.com/activities/159750587
Posted : 21/04/2015 6:23 pm
Your route is described here. Sounds like your enjoyment is dependent on how happy you are in jumping over water bars.
www.mtbtrails.info/Trail_Venue_Map_TrailViewer.aspx?VenueNumber=27&TrailNumber=162&Unique=635652452699513338
Posted : 21/04/2015 8:50 pm
I was eyeing it up last year but my friend was a bit ill so we just went up from the eastern end and back same way.
It is a hell of a descent back to the road.
Posted : 21/04/2015 8:55 pm
yeah some of the waterbars are pretty big and come at you pretty fast going down there, definitely good bunny hop practice/closing your eyes and saying "**** it"
Posted : 21/04/2015 9:04 pm
Did it a couple of years ago the day after doing the 'Big' Loop.
There's some right hike a bike over rocks, It wrecked my shoes & I won't be doing it again.
HTH.
Posted : 21/04/2015 9:49 pm
Thanks guys. I think hike a bike is to be expected in those parts.
Quite a few won't-be-doing-it-agains in there. Is that the hike a bike aspect, or the descent in at the end not being worth the effort?
Posted : 22/04/2015 8:55 am
Its a frustrating slog up to the high point as said. A better bet if you like a bit of tech is the final descent as an out and back all the way around to corrie mich fairchair (sp)
Posted : 22/04/2015 9:42 am
I've walked up to the triple buttress for a look at the remains of the Lancaster. That might be a go-er, although from memory, some of that path might not be all that rideable, there was a lot of gaps between the rocks.
Posted : 22/04/2015 9:48 am
Some of it isn't ridable (by me anyway) but its fun to try. Depends what floats your boat spose.
Posted : 22/04/2015 9:59 am
Very true ๐Ÿ™‚
Posted : 22/04/2015 10:03 am
the hike a bike is sustained and timewise is a significant part of the ride. I'd say you should do it and then make your own mind up, stunning place to be anyway and good fun coming down.
Posted : 22/04/2015 10:46 am
The descent is most definitely worth it, unless you struggle on steep-ish rocky terrain?
Posted : 22/04/2015 11:29 am
I'd say definitely worth doing at least once. If its a good day then just stop and take in the surroundings every so often and think yourself lucky you're there. It is a cracking descent. I treated the climb as a series of trials challenges and tried to ride as much as I could even if it was only 10m. My mate didn't stop once his bike was on his back and he hated it.
Posted : 22/04/2015 11:37 am
chakaping - Member
POSTED 5 MINUTES AGO # REPORT-POST
It's the water bars with another a bike length after that **** it for me. Hike a bike is too big a % of the ride too. Scenery is always going to be amazing up there, but if you're banking on the descent then you'd be better off just doing an out n back from the road
Posted : 22/04/2015 11:38 am
Not at all worried about the descent ๐Ÿ™‚
Posted : 22/04/2015 11:39 am
The view off the back is pretty spectacular BTW...
[img] ?oh=0aeace0b6309d92b9a1c018412d60f14&oe=55D63FC4[/img]
Posted : 22/04/2015 12:08 pm
I biked up to where the path splits and then walked to Coire Mhic Fearchair and up to bag the Ben Eighe summits - rode the descent and thought it great.
Another option for a route is up from Annat and around the west side of Meall Chean Dearg. It's lovely, flowy singletrack and there are excellent views of Ben Damph and up close An Ruadh Stac is one the most dramatic peaks in the area. It's an out and back (again I did this en route to bagging the munro). I've fancied tagging this on to 'the lollipop' route but there's a 1000 foot carry and last time I couldn't face it.
Posted : 22/04/2015 1:23 pm
I was looking at that as a possibility for the return leg of the lollipop. Can make that call at the bothy on the way back I guess ๐Ÿ™‚
Excellent info, cheers everyone ๐Ÿ™‚
Posted : 22/04/2015 1:34 pm
I attempted kunstlers route as a mini lollipop(anticlockwise) but couldn't find the start of the path that drops down towards the bothy, its not a continuation of the main path, you have to head off piste a bit and was buried in the low cloud somewhere so I gave up and returned the way I came.
The drop down to the bothy looks great from the bottom though - next time.
Posted : 22/04/2015 2:25 pm
twang - you have to turn left at the top of that path as you reach the bealach. Have a look on google satellite image and you'll see the path quite visible. Not much use when you're stuck in the clag I know - but probably a point to bear in mind if you use it as a climb and then need to locate the descent down the other side. I've had a lot less head scratching moments since I started using gps.
Posted : 22/04/2015 3:23 pm
