toughest/stiffest.....
[Closed] toughest/stiffest......cove hustler or turner 6 pack?
 ton
been offered either of the above frames.
both very nice...........question is i have not ridden either.
which is the stiffest/most robust?
anyone ridden either.
Posted : 30/01/2011 11:40 am
 LoCo
I know of a few hustlers that have broken on the top tube just in front of the seat tube, and not replaced under warranty.
Can comment on the 6 pack, but have always liked Turners.
Posted : 30/01/2011 11:42 am
ton, I ride my hustler day in day out and have been doing so for about 2.5 years now. Ride it on the local DH courses and on the rough mountain stuff here. I've wrecked my pikes, the rear shock, stripped my XTR cranks, wrecking my wheels and pretty much worn everything else on the bike out at least once. I have replaced the bearings once. All I can say is that the frame is still going strong. It's ding free, a bit scratched etc but it's still running well.
That is just my experience. I'll change the bike this year, it's time for a change, but I have to put my hand on my heart and say the Hustler has been a great bike for me.
Posted : 30/01/2011 12:10 pm
Six Pack has better suspension, and is probably stronger.
Hustler is plenty stiff and strong, and has better geometry (lower and slacker).
Having had both, and given the choice, I'd go for the Hustler every time.
Posted : 30/01/2011 12:18 pm
Turners come in man sizes, L, XL, XXL up to Sasquatch which is enormoose, the bushings last an age and are easy to change,
Posted : 30/01/2011 12:43 pm
Hustler - Well tested and thrashed, bearings replaced after 2.5 years and even then only one set needed doing.
Used a pushed RP3 at 280.
I would have thought the six will weigh be a fair bit more.
The Cove makes a great do it all trail bike, best at around 140. Turner is best with Lyricks, 36s etc
Although I had a 5 spot I only used it when the cove needed work/parts.
Posted : 30/01/2011 1:44 pm
Turner. Plus you have the best CS in the business if you need it.
Posted : 30/01/2011 1:51 pm
ive had both and ridden them extensively.
6 pack wins every time. brilliant bike. i rate it.
Posted : 30/01/2011 2:41 pm
