As above, the pump has lost compression, but I cannot work out how to remove the shaft ,in order to change the o-ring. There are two small holes on the plastic part at the top of the shaft, and the American sites say that if you insert asmall allen key it will free the plastic part,so that you can remove the shaft,but it doesn't on mine. Has anyone managed to do this ?
Posted : 07/07/2021 9:32 am
