Top tip required - ...
[Closed] Top tip required - braided brakelines through enclosed guides - easier way?
Trying to fit some braided lines to a new build, the frame has enclosed guides for the rear brake line... have managed to get the line through one (with much cursing) and now face another 3 to go which arr proving just as difficult! Once the line is through things are fine, it's not tight or anything, it's just getting the cut end through in the first place that's causing me grief... so, any top tips for the home mechanic? Or do I just have to be forceful and patient?
cheers ๐Ÿ™‚
Posted : 09/02/2010 9:19 am
trim the end to a point and then recut once your through?
be thankful your not trying to get it through a five swingarm, spent an hour or so cursing the designer that came up with that hose routing last night....
Posted : 09/02/2010 9:25 am
Good top tip! shall give it a try ๐Ÿ™‚
Posted : 09/02/2010 9:27 am
with braided the other thing to do is to put a really tight wrap of electrical tape around it prior to cutting (it helps avoid frays) and leave it on whilst threading.
Posted : 09/02/2010 9:29 am
hurrah, success... though now I discover that I've ordered the hose a tad too short ๐Ÿ˜ณ could've used an extra 50mm or so, **** it!... ๐Ÿ‘ฟ
Posted : 09/02/2010 9:56 am
solve the short hose with a 90degree connector.
Tis what i did on a bike.
Posted : 09/02/2010 12:10 pm
oooh, what's that then? google doesn't throw any light (well it does, but what type of 90 degree connector am I looking for, I'm guessing not HDMI right? ๐Ÿ˜† )
EDIT: a-ha, found it... but how will that help me?
Posted : 09/02/2010 12:18 pm
if your running hope stuff (assumption there) it just meant my hoses route towards the toptube was more direct.. and the loop at the bars did'nt need to be so big. (i botched cutting the hose basically)
Posted : 09/02/2010 12:28 pm
old wire coat hanger or welding rod , but a kink in the end feed through with brake pipe taped to it
Posted : 09/02/2010 12:38 pm
cut a strip of plastic milk carton and roll into a funnel type shape, put the narrow end of the funnel into the hose guide and feed the hose through. The funnel shape will direct the hose into the hose guide.
Posted : 09/02/2010 12:41 pm
cheers chaps... plenty of good options there ๐Ÿ™‚ have now ordered another hose length, this time with a fair bit extra for safety! a lesson learnt ๐Ÿ™„
Posted : 09/02/2010 12:54 pm
Spare front hose now?
Posted : 09/02/2010 1:22 pm
indeed... though it's a little short for this bike I hope it'll come in handy another time ๐Ÿ™‚
Posted : 09/02/2010 1:24 pm
