Top swing, bottom s...
[Closed] Top swing, bottom swing. Discuss.
I understand the principle of top/bottom pull - I need a top pull.
Any reason why I couldn't get a top swing for the hardtail? Are the smoother/betterer, less clag friendly, easier cable run, etc etc?
Sigh. This is what my life has become.....
Posted : 14/01/2009 11:09 pm
I think that the top swing is more compact which makes it fit better on more congested frames
Posted : 14/01/2009 11:12 pm
plus the bottom swing has a gear cable running under your dirt covered bottom bracket so more likely to clog up etc
Posted : 14/01/2009 11:14 pm
Go singlespeed? ๐Ÿ˜†
Posted : 14/01/2009 11:15 pm
so you are talking 'top swing' vs 'conventional'
sometimes the bracket of a conventional front mech clamps where the seat post bottle boss is - this could prove restrictive depends on your frame.
in use ive found the conventional ones dont get bunged up with carp so much which results in a fail to shift to granny
the cable run on a top swing mech more neatly follows the seat tube, the conventional has to come out as more of an angle.
zzzzzzzzzzzzzzzzz
Posted : 14/01/2009 11:25 pm
both Tim and particularly junkyard should be ignored completely re their advice , the term top and bottom swing relates to the position of the cage in relation to the clamp. ie if the mech plates are below the clamp it's a bottom swing.both top and bottom swing can be either top or bottom pull depending on the mech you choose . many shimano mechs can accomodate both top and bottom pull set ups. often with full suss frames a bottom swing mech (conventional..and more durable I believe) is not possible as the clamp position is blocked by a shock mount...hence the necessity to pick a top swing. there may be other instances /advice on it's way but as usual ..many people offeringf advice on stw really haven't got a clue.
Posted : 14/01/2009 11:37 pm
never thought why i have a top swing on the fs. ta.
Posted : 14/01/2009 11:40 pm
