top jockey wheel ca...
[Closed] top jockey wheel catching on 34 t casette
b adjust screw wound as far as it will go and the jockey wheel is still catching any possible solutions ta
Posted : 18/10/2012 10:40 am
mtfu and get a 32 ๐Ÿ˜‰
Posted : 18/10/2012 10:41 am
longer b tension screw.
what frame is it ?
Posted : 18/10/2012 10:42 am
Check the chain length.
Posted : 18/10/2012 10:46 am
Untighten the bolt that attaches the mech to the mech hanger & see if it moves away from the cassette slightly.
Posted : 18/10/2012 10:48 am
Is it a medium or short cage rear mech? You often need a long cage mech for wider range cassettes.
Posted : 18/10/2012 11:34 am
Had a problem like this with an X4 mech. The b screw bears directly on the back of the hanger and a minor off can cause the screw to find a new 'home' in the soft alloy of the hanger making it difficult to put any tension on the b screw.
Not a problem with more expensive mechs they have a steel tab to protect the hanger.
Posted : 18/10/2012 11:47 am
