Today's Doh! Moment
[Closed] Today's Doh! Moment
[#10643698]
When I flipped my stem, face plate off, garmin stem mount off, remove and replace spacers, replace bars and face plate, align stem and torque bolts....to realise its a 0° stem and it's exactly the same angle however you mount it
Posted : 28/05/2019 8:20 pm
Good job you don't work in a bike shop😉
Posted : 28/05/2019 8:46 pm
When you are not happy with your latest bar tape affort as there is a 1mm lift on the bend, then having removed it down to the shifter and put 2 turns back on it, it snaps in half.
Screw you Deda Mistral bar tape
Screw you funny shaped aero carbon bars
Posted : 28/05/2019 9:24 pm
Fettled and cleaned but it just didn't feel right.
Posted : 28/05/2019 10:13 pm
Lol! Something I’ve done more than once is fit a new hollowtech bottom bracket without the required spacer.
Posted : 28/05/2019 11:41 pm
Bleeding the brakes today, forgot to put the bleed block in the front brake and popped out a piston onto the shed floor🙄
Posted : 28/05/2019 11:49 pm
I did the Shimano brake bleed thing with the cup fitted to rear brake lever, and syringe fitted to front caliper. Lucky the whole system didn't explode with the had shaking compression I was putting on the syringe. Idiot.
Posted : 29/05/2019 10:29 am
That's a pressure test and is just good practice nanny, good work.
Posted : 29/05/2019 11:01 am
Loving the SRAM crank arms! Never seen that before 😆
Posted : 29/05/2019 11:13 am
Keep it. Gives all the benefits of ovality without having to shell out for a new chainring.
Posted : 29/05/2019 11:21 am
Check out the 'if you can fix a...' recruitment ad from the Navy..
Posted : 29/05/2019 11:27 am
I found a vid of it working 🙂
Posted : 29/05/2019 12:06 pm
I spent a couple of minutes checking gears and rear wheel before I spotted it.
Shimano doesn't allow it to happen so I just assumed that if it went on.....
Posted : 29/05/2019 1:33 pm
