to users of Titec j...
[Closed] to users of Titec j bars, a question
how much room is there for grips, brake levers and a shifter pod?
pics of your set up would be doubly useful
Posted : 05/04/2011 8:10 am
bump for the late morning crew
Posted : 05/04/2011 9:54 am
Much better suited to ss use as there's not much room for brakes and shifters ... I believe the loop bars are better for geared use. SSS will tell you ๐Ÿ˜‰
Posted : 05/04/2011 10:05 am
Jones J Bars are great, loving mine
Just started using these after years on risers
Feels very natural and I got used to it very quick
Grips not a problem.... Brakes - sit a bit higher
Shifters - dont know as I dont have as running SS
Posted : 05/04/2011 10:12 am
Set up from a while back, now have alfine shifter fitted and its very tight.
Posted : 05/04/2011 10:37 am
RD - been fiddling with this conundrum for a bit (as well as lengthening hoses to get bivvy gear strapped on un-impeded). Will post up some pictures later. Running Avids and XTR shifters - the latter can slide to give some 15mm of play in final position of shift levers which helps. Still a work in progress too.
Posted : 05/04/2011 11:21 am
RD - a shot to show you can squeeze it all on there... like I said still fiddling with hoses and will get grips on there in the next day or so. Everything mounted forward of the main bar allowing one finger braking and enough room underneath for the shifters to be operated. HTH.
[url= http://farm6.static.flickr.com/5173/5592702411_922c26c1c2.jp g" target="_blank">http://farm6.static.flickr.com/5173/5592702411_922c26c1c2.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/99percentchimp/5592702411/ ]Titec H Bars 3[/url] by [url= http://www.flickr.com/people/99percentchimp/ ]99percentchimp[/url], on Flickr
Posted : 05/04/2011 9:06 pm
cheers, not sure there's enough room for me there, got some flat carnegies on the way to try first
Posted : 05/04/2011 9:18 pm
 cozz
There isn't much space at all i tried and ended up using dual control shifters on mine which i really like. But I know some people hate them
Posted : 06/04/2011 9:43 am
