To find if a bolt i...
[Closed] To find if a bolt is an M8 bolt, do you......
sorry maybe a daft question but do you measure the diameter of the 'shaft' and if it's 8mm it's an M8?
Posted : 01/02/2011 7:19 pm
Yes ... but that won't tell you the pitch. STD M8 is 1.25mm but on certain applications a pitch of 1mm is quite common.
Posted : 01/02/2011 7:30 pm
It's just for shock mount bolts, does that matter?
Posted : 01/02/2011 7:32 pm
I'd be inclined to suggest M6 as a more likely size...
Posted : 01/02/2011 7:33 pm
Yes all you have to do is measure the diameter, 4x 2 pence pieces for M8 or 4x 1 pence pieces for M6 ๐Ÿ˜ฏ
Posted : 01/02/2011 7:35 pm
could be a 5/16 though. (7.93) measuring accross the shaft might not help if the thread is rolled.
if it is m8 it should be 1.25 pitch so 8 threads should be 10mm apart. bit easier to measure.
if it is a standard bolt the a/f of the head will be 13mm. 5/16 will be 1/2 an inch. if it has 8.8 stamped on the head it is prolly metric
Posted : 01/02/2011 7:36 pm
See if an M8 nut will fit on it nicely, if it does it's an M8 bolt ๐Ÿ˜€
Posted : 01/02/2011 7:41 pm
this is all getting very complicated ๐Ÿ˜•
there isn't actually a thread, it has a smooth shaft that goes inside the bushings
Posted : 01/02/2011 7:42 pm
 jeff
pro-bolt have a handy PDF doc with a bolt finder in it.
Just print it with no scaling.
Posted : 01/02/2011 7:43 pm
Pick it up and look at it. I it looks like a M8 bolt then it is. Works for other sizes and threads too.
Posted : 01/02/2011 7:45 pm
ah well, m8 implies it has a metric 8mm thread. borrow some calipers off someone and measure it.
Posted : 01/02/2011 7:47 pm
If it's a M8, it will always be first to get a round in...
 flip
If it's a M8, it will always be first [s]to get a round in..[/s] to give a reach round..
Posted : 01/02/2011 8:02 pm
Got to B&Q and try a M8 in the shop.
Posted : 01/02/2011 8:22 pm
