anyone recommend a seller, i can see packs on ebay but i have no use for all the other sizes.
i'd happily buy 10,20,50, 100 but i'm not looking for 1000s to save a few pennies
ebay;
Guessing 5x2 (ID x thickness in mm) but I would check yourself
I use a silverline O ring selection pack from toolstation in those little boxes. They have worked fine on mine.
I got these ones, and they fit just right over presta valves.
excuse the silly question, why do you use these?
I don't use them on all my wheels, but on some rims the lockring kept coming loose, and the o-rings stopped that from happening.
The RRP Valveguard does that job. £3.99 for a pack of 6.
do you need the screw on bit? I usually lose mine the 1st time I pump the tyre up
Thanks guys, didn’t think of tool station ,
ill just get 10 on eBay for now, didn’t find that when I looked earlier..
I find on certain tubeless valves and rims combinations an o ring can be the difference between a leak and an airtight seal
The OP is tubeless I assume.
