Titus Motolite carb...
[Closed] Titus Motolite carbon/alu rear loose is there a fix?
Hi, in my shed there is a 26er Motolite (not much use at all) with a carbon rear that has a alu bridge on the rear wheel
[img][url= https://farm1.staticflickr.com/744/22078942231_c98418034e_c.jp g" target="_blank">https://farm1.staticflickr.com/744/22078942231_c98418034e_c.jp g"/> [/img][/url][url= https://flic.kr/p/zD3miM ]IMG_20151010_114334788[/url] by [url= https://www.flickr.com/photos/50879761@N05/ ]vondally[/url], on Flickr[/img]
the bridge has come loose, the right hand stay, it moves slightly meaning the whole rear moves when you twist it by hand.
[img][url= https://farm1.staticflickr.com/763/21447822073_a2aeed8258_c.jp g" target="_blank">https://farm1.staticflickr.com/763/21447822073_a2aeed8258_c.jp g"/> [/img][/url][url= https://flic.kr/p/yFgGgK ]IMG_20151010_114317579[/url] by [url= https://www.flickr.com/photos/50879761@N05/ ]vondally[/url], on Flickr[/img]
I have sent a highly trained athlete out on it aka the Test Monkey aka SO who said she could not feel it move and ohhh it is rather a nice bike......
are there any fixes?
All the other cables stops seem to be riveted, could this be done and if so by whom?
or do I salvage/sell it in parts? Though not seeing much call for 26 parts?
Thanks
Posted : 14/10/2015 7:07 pm
 gee
A relatively common fault with those rear ends. Titus just bonded them back in again.
Posted : 14/10/2015 7:12 pm
So how would I do that and what would I use? The movement is less than a cm, so would I just knock it up and then bond/glue back?
Posted : 14/10/2015 7:15 pm
Carbon Bike Repair in Dorking may be able to recommend something.
Posted : 14/10/2015 7:21 pm
I used epoxy type stuff from B and Q on mine. Worked a treat.
Posted : 14/10/2015 8:23 pm
any type of epoxy stuff? Brand or what works best?
DO I just try a bond that side - given the movement in less than a cm or do I try and take the bridge off and then rebond?
Posted : 15/10/2015 10:58 am
I would use a 2-part epoxy like Araldite. Do the loose side and some on the other to re-inforce. I wouldn't take the bridge off - try and do it in-situ. Make sure its nice and clean before you do.
If you have the confidence to do so I would also drill and put a rivet in either side.
Posted : 15/10/2015 11:39 am
