Titanium bolts on a...
[Closed] Titanium bolts on a DH bike.
[#6939951]
Good evening all,
Just wondering if ti bolts on certain parts like lower crown bolts and pinch bolts on dual forks are ok?
I believe they're the same strength as steel but wanted to check.
They're being used for rust resistance more than anything else. And definitely not for weight 🙂
Thanks
TomO
Posted : 18/03/2015 12:06 am
Good enough for Russian migs, good enough for specialized demo
Posted : 18/03/2015 12:14 am
How did you know I had a Demo? Stalker warning is at level 10 😉
Posted : 18/03/2015 12:45 am
If it's not for weight (and frankly there are cheaper and less costly routes) then use stainless steel instead. 1/10th of the cost and rust resistant.
I replaced everything with stainless I could on my bikes, tarts them up no end.
Posted : 18/03/2015 12:48 am
Thread history in your profile:
[url= http://singletrackworld.com/forum/topic/what-are-these-parts-that-came-with-my-new-s-works-demo ]singletrackworld.com/forum/topic/what-are-these-parts-that-came-with-my-new-s-works-demo[/url]
Turn that stalker level up to Def Con 4. 😉
Posted : 18/03/2015 12:50 am
Haha I forgot my previous thread.
I run stainless at the moment on my trail bike and rust seems to appear even with me using bike spray etc.
Feel like giving ti a go, if I have the same issues at least I can say I tried 🙂
Posted : 18/03/2015 12:55 am
Buy better stainless.
Posted : 18/03/2015 1:35 am
^^ this
If they're rusting they're not stainless. Clue's in the name! Ti is a waste of money really.
Posted : 18/03/2015 8:29 am
Swapping out 'like for like'sized bolts from steel to titanium alloy can cause flexure problems in highly loaded areas like fork crowns and stem clamps.
I experienced this first hand some years ago installing quality titanium bolts into a Thomson x4 stem and going to Woburn Sands. Despite being set at same torque, my Pro Atherton DH bars felt 'flexible', and made frightening creaking noises. I installed the original bolts when I got home and never experienced this problem again.
Steel and titanium bolt of same size / cross section; the steel bolt is stiffer (resistance to loading) meaning a titanium bolt may be a bad choice. Often with components fitted stock with titanium bolts, you'll see a different size of bolt or longer thread depth.
I only use titanium for fixings like shifter / brake lever clamps, or pinch bolts on derailleurs.
Posted : 18/03/2015 9:02 am
Ti is not a waste of money if you have enough of it
It is the king of metals and sets the standard by which all other metals are judged
Posted : 18/03/2015 9:34 am
 br
I run Ti bolts where I can't or don't want to run aluminium ones - ie rotor bolts, mech bolts etc. And steel in anything 'stressed'.
Posted : 18/03/2015 9:50 am
Pah, alu in all of those. 1/10 the cost and 1/2 the weight, [i]and [/i]pretty colours!
Platinum? Not much use for bolts admittedly!
Posted : 18/03/2015 10:17 am
Ndthornton is wrong. Tungsten is the king of metals. Dense strong and high melting point.
Posted : 18/03/2015 10:35 am
If this is true why is my shower gel called Titanium? I used to have a razor called Titanium but it became blunt and I threw it away (clearly not really Titanium). David Guetta claims to BE Titanium in his song?? Parts of my Dad really are Titanium!!
Everyone wants to be Titanium.... Not steel, Aluminum, Tungsten, Platinum
TITANIUM!!!!!!!
Posted : 18/03/2015 10:57 am
Good enough for MotoGp, good enough for me. Fitted where ever possible on my bikes since 2004. Stainless steel in it's lower grades CAN rust. Put a 304 grade bolt in a saline soloution and watch it turn ginger. Don't buy cheap grade Ti bolts,some of the quality out there is terrible and I speak from experience. The correct bolts will have the threads rolled not machined / die cut. They are much too good for the purpose but hell they look good. Still have some of my origonal bolts fitted too, from 2004
Posted : 18/03/2015 11:21 am
Go on then, I;m biting. Where can I get some good quality Ti bolts...
Posted : 18/03/2015 11:43 am
Pro Bolt are very good. Avoid Superstar, if they even still do them, I had several and they were dreadful - distorted heads and what not.
Posted : 18/03/2015 11:51 am
Superstar
There are two common grades of stainless bolts A2 and A4 - this will be stamped on the head of the bolt.
A2 is roughly comparable to 304 stainless - and is not suitable for sal****er, etc.
A4 is roughly comparable to 316 stainless, and is suitable for sal****er in certain applications.
A4 bolts/fittings are more expensive, but will not corrode like A2.
(we build stuff for Navy Ships/submarines - so I know a bit about this)
Posted : 18/03/2015 11:52 am
Is there any problem with fatigue in ss due to work hardening?
Posted : 18/03/2015 12:22 pm
Stainless Steel can rust, even food grade Stainless Steel like 440B can rust under the right/wrong conditions.
I've noticed a lot of products that say Titanium are actually Titanium Aluminium Nitride Coated so it keeps the edge for longer. There are better coatings to use, but they won't because it will make it last 10x longer. 😉
I've forgotten the name of it, but there is a coating you can buy from the states that is used by the US Navy to stop things rusting and it works very well. EDIT: Corrosion X
Posted : 18/03/2015 12:33 pm
Totally agree with njee20. ProBolt are very good but not very cheap, they are what I use. Buy a few at a time and you don't notice it as much. Avoid Superstar.
Posted : 18/03/2015 8:56 pm
Pro bolt is who I bought the bolts for my Thomson stem from - we used to sell a lot of pro bolt at freeborn as the boss was a motorbike enthusiast.
Posted : 18/03/2015 9:29 pm
I would go with this ^
Remember strength and stiffness are two completely different things. You can alter the strength of material by alloying and processing changes but the stiffness (modulus) will stay the same (well slight change with some alloys). A bolt stretches due to it's modulus so a lower modulus means clamp etc can open up under load and can lead to fretting of surfaces being clamped.
titanium will be about half, aluminium is about 1/3rd compared to steel. So it would be like reducing an M6 bolt to little over M4
Posted : 18/03/2015 11:56 pm
Check you're not using A2 stainless (generally S304). You should use A4 grade stainless (S316) for corrosion resistance.
Just realised freeagent has said much the same but I'll leave my efforts here for confirmation ?
Posted : 19/03/2015 8:05 am
Which are exactly the characteristics that make it such a splendid conversation-starter and focus of creativity when made into a [url= https://www.kickstarter.com/projects/1014603694/forge-solid-denser-than-solid-uranium ]Tungsten cube[/url]...
Posted : 19/03/2015 8:11 am
