@steexysix I like your sentiment. Totally agree.
I don’t want to be one of those “WHAT??? HOPW MUCH???” type people but what’s the advantages of racks like that over one of the less fancy looking racks like alpkit and topeak?
I don't have a Tailfin so can't confirm, but what I have read is the main advantage is rigidity, including the panniers. Apparently nothing moves even when climbing out of the saddle. From a design point of view I like the axle mounting system which avoids frame mounts - should be stronger and is quickly attached and detached.
Podsacs fork bags (4 or 5.5l) work well as micro panniers. They used to be cheap, sure I paid about a fiver a pair.
Thule pack n pedal rack is the danglies, we use modified (widened) ones on our fatbikes.
Good point. The Tailfin rack, by giving you triple boss fork mounts, opens up any of the fork mounting solutions.
Which also makes me wonder if it would be advantageous to have something made that simply provides fork style mounts where panniers would go, with no rear deck at all. You could get some great stability that way, and the results could be pretty light.
My wife uses an Ortleib mini pannier, designed for the front but she only uses on the rear rack of her bike. It was a gift. It's had dog's abuse and is still going strong after many years. Still totally waterproof. I can't find what exact model it is, as they seem to have changed a bit in design. But they seem to still do small panniers.
Apparently her friend bought a pair, and didn't need two so gave her the spare.
The original Tailfin T1 was exactly that. I would hazard a guess that the current X Series which can take a top bag as well, isn't much heavier.
That's still a pannier rack rather than an anything-cage rack.
Ah I see what you mean.
£249 for a pannier rack?? Even the Tubus Titanium ones are only half that!
That’s still a pannier rack rather than an anything-cage rack.
Not quite sure what an anything cage rack is but is it like a lowrider rack?
Talking of cages, what about a couple of Blackburn Outpost Cargo cages with 5l dry bags?
The Tailfin X-three is only £129 for the rack - this will fit normal panniers with some extras.
I have the S-three which is only £99, and has the anything cage bolts on the side.
I got some of those planet-x podsacs with the cages included when they were not silly money.
The cage is pretty good, the bags not so much.
I'll second @yourguitarhero , got the same Tortec rack from Wiggle on my Pompino. I use the Ortlieb gravel packs because the size is just right (potential for heel strike on the Pomp). I had to add a couple of spacers to clear the V brakes but it's good and solid.
An "Anything cage" is a large cage that fits to three bottle bosses, it's made by Salsa, review here - https://bikepacking.com/gear/salsa-anything-cage-hd-anything-bag/ . There are several similar models such as the Gorilla Cage. Some forks come with the three bottle bosses on each side so you can fit a pair. I installed a set on the downtube of my fat bike using Rivnuts to add the bosses.
Bikepacking.com have a list of those available - https://bikepacking.com/index/cargo-cages-anything-bags/
My train of thought is to use a drybag on the top of the rack.
Any suggestions as to a good quality drybag with good abrasion quality
My wife uses one of these - https://alpkit.com/products/airlok-xtra-dual-13-litre , there's a 20L version as well.
An “Anything cage” is a large cage that fits to three bottle bosses
Got it, thanks. It was the ‘rack’ bit I was unfamiliar with. Assuming now that there are racks out there which have three fittings for cages?
This guy goes one better:
it's a really neat idea, he can make them for front or rear & add bosses to racks. It's a simple bespoke way of bikepackifying your regular bike (as long as it has bosses). He makes some really nice items.
I reckon a minimal rack design with 3 bosses per leg and a concave top to accept a dry bag would be a great product.
That S3 is almost what I am thinking of but I want the top strut to be much shorter. The legs with the bosses on could then slope up towards the saddle, this would put the centre of mass a lot further forward which would reduce waggle. It'd be a bit like having cage mounts on your seat stays, but with wheel clearance.
Pretty tempted to bust out the 3d printer and make a prototype. Anyone got a CNC machine?
I used the Zefal gizmo bosses on my forks to hold some Blackburn cages. Works well, costs about £10
I have a Lomo rack bag on my front rack mainly for commuting, as recommended by someone on here at the time. It will fit a rear rack too although it is slightly wider than a rack the roll top clips round the rack to snug it down. It's very solid and you can open it more easily than a normal dry bag to get stuff out en route. Good value too.
Their dry bags are also said to be solid.
https://www.lomo.co.uk/acatalog/dry-bike-tail-bag.html#SID=152
I keep looking at box section carbon fibre tubing and wondering if it's possible to build a rack similar in construction to how Atherton bikes are assembled, using 3d printed lugs and epoxy. Might be an interesting (and probably very light) project.
