I'm considering purchase of a Ti 100mm hardtail frame & just wodered what peoples thoughts were on fitting either a Ti, carbon, or Scandium seatpost??
Any rides benefits of either in a Ti frame?
I've got a Ti seatpost in my Ti frame. To be honest I didn't really notice much benefits over the alu post it replaced other than being a lot lighter and nicer looking.
There's an alu sleeve/shim in the seatpost to minimise any binding problems caused by the seatpost interface with the frame.
It's not usually a problem on smooth joins (much more with threaded joins like a Ti BB) but use CoppaSlip if you put a Ti seatpost in and specific carbon grease if you use a carbon post.
I've gone from a Thomson to a Ti post on my Ti frame and I certainly felt the difference. It's made the ride loads comfortable.
Carbon post in my Ti frame, a lot comfier than the alloy one I had previously, but, it does seem to 'seize' in - not sure why.
I had a carbon post in my Ti frame and it was fine. Then I got a Ti post and it's been amazing. Wish Id done it ages ago.
Thanks, Ti post seems favourite.
Is Scandium much different to Ti or more like aluminium?
i got a ti frame with a thomson but have just spent silly money on an erikson post cause ssstu says they was good 🙂
Stoner - which post model did you go for?
I have a Ti post that moves around all my bikes: cos if your bike is not 27.2 it's a bit rubbish and I can get an inch of travel out of my Ti post.
Go Ti.
Charlie - its 31.6. Are you saying bigger than 27.2 will be stiff but 27.2 is narrow enough to have some flex?
27.2 suits me as all my bikes are on-ones (27.2)
Dickie, Got a van nic from on-one. for £95.
Currently £90 in the sale
http://www.on-one.co.uk/i/q/SPVATI/van-nicholas-titanium-seat-post
2nd the van nic post - I've got two on the go and they do add a lot of comfort over a Thomson etc.
Cheers, 31.6 in line currently out of stock!
Heavier than a Thomson though.
[url= http://cgi.ebay.co.uk/270754722825?ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2Fi.html%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D270754722825%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1 ]ebay Ti Post[/url]
What about this? Cheap rubbish or worth a try?
