Thule 598, moving t...
[Closed] Thule 598, moving the tray forward ?
5 Users
So there is more space to slide the front wheel holder forward ? Must be a way, can’t find it in instructions....
Posted : 27/11/2017 5:55 pm
The trays just slide until they hit the stops.
Not sure that helps though 😕
I think I thought about this when I got mine and looked at moving the clamp assembly backward, but couldn't. It's not a problem with our Large Fat and Full Sus bikes.
Posted : 27/11/2017 5:58 pm
Yeah, it’s the clamp assembly I mean, so there is more allloy channel in front of it. I need the tray to go about 2cm further forward than the stops..
Posted : 27/11/2017 6:03 pm
I don't think it can be done, but I'd be delighted to be proved wrong.
Posted : 27/11/2017 6:05 pm
Hmmmm.... I know it was possible with the older 591’s ...
Posted : 27/11/2017 6:14 pm
Yes it was, I think the pay off is that with the 598s it's less faff swapping the clamp around for different sides of the vehicle.
Posted : 27/11/2017 6:18 pm
Hmmm, thats bit rubbish...
Posted : 27/11/2017 9:16 pm
I slide my front tray past the stops, end up about 1/3rd hanging off the front. Not been a problem yet.
Posted : 27/11/2017 9:51 pm
Would moving the upright clamp section backwards help? That's what I had to do with mine, works fine.
Posted : 27/11/2017 9:53 pm
Yes, moving black clamp back wrt the alloy rail is basically what I’d like to do. On the old 591 it was a case of getting into the bolts that connect the black clamp unit to the alloy rail section. Will have a look in daylight....
Posted : 27/11/2017 10:08 pm
I did it on my 598s. There's two grey plastic half turn clips underneath I think. Undo them and underneath is the bolts that hold it to the rail.
Posted : 27/11/2017 10:20 pm
^^^^ nice one, thanks 🙂
Posted : 27/11/2017 11:12 pm
Are they underneath a black plastic cap as I need to mine as well
Posted : 28/11/2017 7:07 am
Any progress? Is it doable?
Posted : 30/11/2017 9:44 am
yes ! Did it earlier, undo the wee grey lock plates (the ones you use for swopping sides) and then molegrips onto 2 bolts, slacken, slide, redo. I moved the tray forward about 5cm, fits fine now.
Posted : 30/11/2017 12:20 pm
Posted : 30/11/2017 1:45 pm
The bolts are a fiddle as no space for spanner or socket wrench
Posted : 30/11/2017 2:11 pm
