Through the frame r...
[Closed] Through the frame routing... Grrrrr, how in the name of all that's Holy do you ?
[#6791398]
Went to route my Dropper through the frame yesterday.. it has an exit and start hole pre-done. But doesn't seem to be sleeved.
No matter how many time I tried it, bending one way, waggling the other I couldn't get anything at the other end... Even trying from the other end.... still no good....
Whats the secret ?
Posted : 19/01/2015 2:17 pm
Cotton & a vacuum cleaner
Posted : 19/01/2015 2:19 pm
no idea what the secret is, but ticking theread as Im sure I will need to know one day soon.
EDIT: How about feeding cotton into the first hole and putting the hoover nozzle against the other end 😉
Beaten by the Dog! Damn.
Thin garden wire 😀
Posted : 19/01/2015 2:20 pm
WTF.... really ? it actually sounds like a not completely daft idea... but I'd never ever have thought of that !
Invoice will be in the post shortly
Posted : 19/01/2015 2:22 pm
 br
Shine a light in, can you see it?
Posted : 19/01/2015 2:31 pm
 aP
On my Air9 Carbon I just rammed the cable out through really hard in order to break off all the sticky out bits of carbon inside the chainstay. Worked fine for me, but took about 4 hours to route the rear derailleur cable. Hope it stays good for a long time as I have to take the BB and EBB out to replace the cable. Stupid bike.
Posted : 19/01/2015 2:33 pm
Park have a new kit for internal routing that looks pretty natty if it actually works !
Posted : 19/01/2015 2:38 pm
I found dental floss and the hoover worked even better than cotton.
Posted : 19/01/2015 2:45 pm
I've used on of those Park kits, bloody ace, turns it into 2 minute job.
Posted : 19/01/2015 2:52 pm
Magnet doesn't mess with the bike's paint job or finish when you scrape it along?
Posted : 19/01/2015 3:13 pm
Looks cool. Not for steel frames presumably.
Posted : 19/01/2015 3:14 pm
"Hope it stays good for a long time as I have to take the BB and EBB out to replace the cable. Stupid bike. "
Replacing is easy.
take old inner out
thread in new inner
take old outer off
thread on new outer.
Posted : 19/01/2015 3:18 pm
rOcKeTdOg - you deserve a life time supply of cookies for that idea.
Posted : 19/01/2015 3:19 pm
It's smooth with rounded corners so it certainly shouldn't, it's almost as if somebody thought about the design *Shock horror*
I can see it not working with steel, but in fairness not many steel frames use internal routing.
Posted : 19/01/2015 3:31 pm
Tried the Park dohicky.Any frame where the hole were big enough for the connectors to go through it was just quicker to do it with wire.
It did take me 6 hours to cable a Cannondale slice RS once
Posted : 19/01/2015 3:38 pm
My new bike arrives this week and I plan to remove the front mech and go 1x.
Am I right in thinking that if there is a cable already in there then its a relatively easy job to replace? An if thats the case, am I best leaving the existing cable in there incase I ever plan going back to a double (obviously I'd be triming it down so it only just pretrudes at both ends
Posted : 19/01/2015 3:43 pm
Put a loop through to catch the wire, as it passes pull loop, voila.
Hoover sounds better, although as it's STW only a Miele will work.
Posted : 19/01/2015 3:53 pm
No, pull it out and plug the holes. It's not that difficult to thread a cable.
I bought a metre of 3.5mm CUNIFER (Copper/nickel/iron) pipe as used in Citroen hydraulic systems; that threads through OK. Also 6mm copper brake pipe works but it's a bit thick.
Usually you can just push the cable down then fish the end out with an old spoke.
