those 'widget&...
[Closed] those 'widget' things up there ^^
[#1332460]
anyone tried one? i think they look good because you arent restricted to a minimum ring of 32t. not sure if i would trust it without a guide and roller though, not to mention a bash!
Posted : 16/02/2010 9:10 pm
It's from Australia, so it works upside down. No roller needed. 😉
Posted : 16/02/2010 9:11 pm
What widget things where?
Posted : 16/02/2010 9:13 pm
sorry, a link would be useful wouldnt it
[url= http://www.widgit.com.au/ ]clicky[/url]
Posted : 16/02/2010 9:20 pm
so are they selling them in the UK now?
Posted : 16/02/2010 9:27 pm
You're a naughty, naughty boy, bassspine.
Posted : 16/02/2010 9:45 pm
Who would want just a 28t ring!?
Posted : 16/02/2010 9:47 pm
dunno, id try a 30 though
Posted : 16/02/2010 9:48 pm
Their blurb starts with this sentence:
Lets assume for a moment, that a mountain bike is being ridden in typical single track terrain where the 32 tooth 'middle' chain ring is used all or most of the ride.
Eh what?
In other words, let's pretend that everyone absolutely needs our product - then, you can clearly see that it'd be ideal for everyone!
Posted : 18/02/2010 9:10 pm
they dont last on kids bikes .......
cant see them lasting on MTBs
product in looking for problem and failing shocker , must give a great chainline too !
Posted : 18/02/2010 9:26 pm
looks like it mounts to the inner tabs but sits where the middle ring would so shouldnt give any worse chainline than a middle?
why dont they last on kids bikes?
Posted : 18/02/2010 9:41 pm
Chuffin expensive though.
Posted : 18/02/2010 9:43 pm
Work out at £80 in the UK. Bet they've sold at least two.
They need to get a grip and drop the price-after all its only a chainring and a couple of stainless plates.
Would like to see a test ruling out chain noise as a possible problem.
They ask you to contact them with any problems....guinea pig springs to mind!
Posted : 19/02/2010 12:41 pm
thats pretty steep! half that would be more like it.
Posted : 19/02/2010 12:44 pm
Wouldn't a MRP 1x9 thingy be lighter and cheaper, and probably more secure?
Posted : 19/02/2010 12:46 pm
As I have said on another two threads on this topic, the MRP chainguide works well (for me), costs £37, weighs 60g and arguably looks better. So ner.
Posted : 19/02/2010 12:53 pm
I run MRP at mo but Widget does look trick...if it works!
Posted : 19/02/2010 12:56 pm
I dont think you have looked at the widget right, its a new ring with and inner and and outer plate attatched to it, so yes its expensive at £80 but if your going down the 1x9 route then probably about the same as a ngear jump stop and bash or the MRP1x9 guide plus a new ring...
flippin eck thats the first pic I have seem of the MRP guide on a bike, its huge !!
Aha, I see what the deal is now. So it seems more competetive than I previously thought. Only limitation is you have to use their rings?
Posted : 19/02/2010 12:59 pm
Oh, and looking at the photo it looks like this chainring goes on the inner ring position?!? Surely that's not ideal for chainline etc.
Posted : 19/02/2010 1:02 pm
No-Still don't see why its so pricey. Most peeps don't want or need a new chainring. Come on UK manufacturer. Get one sorted.
Posted : 19/02/2010 1:03 pm
Hello! Paul who makes the Widgit and is the advertiser is sending one for test any day now. ;] Funnily enough I remeber something similar from the mid 90's made by a guy who raced DH for Pace . Where we are (Calderdale) I can see it'll mak a lot of sense- also with wider spaced cassetes (Shimano are doing a 36-11 for 29er's) the amount of gears you'll lose is minimal.
Posted : 19/02/2010 1:08 pm
Dragging up an old thread.
I think I'm about to buy the Widgit.
The main reason instead of MRP/e13/paul/etc chain devices is that it allows fewer teeth than 32.
It seems pretty unique in this respect, unless someone knows of anything else I can do.
People have mentioned the chainline, the teeth are offset from the bolts so that they are somewehere in-between the inner and middle positions (I think it varies by chainring size).
It is expensive £80 + anything HMRC fancies.
Any owners? Ever dropped a chain?
Did Singletrack ever review one (I haven't seen it if they did). Matt?
Also, I've heard companies saying that a Hammerschmidt doesn't work very well with their suspension designs. I'm likely to buy the 28t. Do you think it's different enough from 32 to cause any problems?
Alex
Posted : 09/09/2010 1:13 pm
I don't really get why you want to limit yourself to a 28T ring only, gaining a bit for the ups at the expense of downs and flat roads
If you've got some properly steep long hills and can't hack a 32T ring then a double setup (eg 22/32, 22/36 etc) (or triple) would seem like a better bet IMO
Posted : 09/09/2010 1:39 pm
Well, a 28x11 is only losing one gear off a 32x11 (it's equivalent to a 32x12.5), so I don't think I'll miss it. The amount of road I do is minimal, and I'm quite happy freewheeling at that speed.
Here in the peak district I'm often using the granny ring, so I thought a 28t would be a good compromise. 28x34 for the moment until I can justify the move to 11-36 10 speed.
Posted : 09/09/2010 1:56 pm
Will a 10spd chain fit a 'widgit' chainring?
£80 seems insanely steep too
Posted : 09/09/2010 2:03 pm
According to Paul at Widgit it will, The Sram ones already do. But I'm slightly dubious of the dyna-sys stuff. People keep referring to a new pitch on the chain but I haven't seen anyone actually do a side-by-side of the chains or quote measurements.
Posted : 09/09/2010 2:16 pm
I guess after doing a bit of invoicing I'll take the plunge then.
Posted : 10/09/2010 12:40 pm
i bought a 28t widgit for a 1x9 29er. the inner chainguard hits the chainstay on a niner sir9 and a salsa big mama. i suspect the problem could occur on other 29ers but probably not on 26ers.
i sent it back for a refund, i lost out on return postage and import tax and vat.
i wasn't happy with the product or losing money and felt like an unpaid tester for somebody else's product. i still like the idea and would like to go smaller than a 32t ring for a 1x9 29er but the widgit won't do it.
Posted : 10/09/2010 12:58 pm
I'm surprised about the 29er thing. I thought that Widgit had done the maths on making each size ring fit within the space normally occiped by a standard chainset. Hmmmm
Posted : 10/09/2010 2:45 pm
i think most 29er chainstays are wider close to the bb shell compared to most 26ers. i was using standard deore cranks, axle and bottom bracket cups.
Posted : 10/09/2010 3:49 pm
