is a 6 litre one better? is the tank enough? is it better (quicker to fill) or a little small (empties too fast)?
not many of the small compressors are in stock anywhere just now, but they are cheaper and take up less space than the 20-ish litre ones.
is it worth the wait for a smaller one (saving some cash) or should i just MTFU and buy the bigger?
6ltr's been fine for me - easier to move around if you want to do the car tyres etc as well.
Probably going to have to get myself one of these too.
Got any links anyone?.. only ones I can find are massive industrial jobbies...
try machinemart
It can depend on how you inflate them as daft as it sounds. I like to feed the air in relatively slowly so I can tend to lose a bit of air but I've never blow a tyre off while inflating. I prefer the 25 litre compressors for this reason.
Cheers uplink, not cheap though are they?? this is the cheapest one I could find at machinemart;
http://www.machinemart.co.uk/shop/product/details/wiz-mini-air-compressor/path/diy-semi-professional-air-compressors-2
Any better (ok cheaper) ones about anyone?
that one doesn't have a receiver tank - it's jut a pump!
plus the bandit is out of stock (and comes with a nailing kit i don't want to pay for since it don't need it) as is the 24l one
Halfords have one around £90 at the mo I think. 24 litre tank, 1.5hp motor.
Oh, is that not the right sort of thing then?
The ones with the big tanks seem a bit OTT for bike tyres?
A friend of mine does his with a garden sprayer type thing! Not seen it for myself though so not sure which one
Folks aren't using then to pump up bike tyres per se [that's what pumps are for]
Most people use them to get tubeless tyres initially inflated
Yes I'm with you uplink, its that constant pressure you get from a compressor, that you cant get with a track pump, that makes doing the tubeless thing much easier. Is there not anything that delivers constant pressure but isn't the size of a party seventy!??? (but costs about the same!)Most people use them to get tubeless tyres initially inflated
Got mine off Ebay - but had to wait until a local one came up.
Aldi - they come around every year and come with a host of gadgets. Will post when they come up.
Used mine last night for Ghetto tubless, cleaning a chain, cleaning out a freehub, drying a bike (lazy) and cleaning out my nose.
How much Wally?....... also would it be ok for ghetto colonic? 😯
i never see what all the fuss is about, ive got two of my bikes set up tubeless and all inflations and tire changes have been done without fuss or failure and excessive sweating with a bog standard track pump...
what are you doing different to me to warrant using a compressor..?
think its down to tyres or tyre/rims combo. Some go up no fuss, others are a right pain
It's sat in the corner of the workshop - why not?
I got mine from B and Q about 60Pounds perfect for tyres, toys, air cleaning
It was about £80. But they often hang around and get discounted to £70 - I went in everyday watching the pile move slowly down the isles into the discount section. It is a big very heavy item, mains powered.
I use a 6ltr unit, the 6ltr tank helps give you the initial burst of air that’s often required. You can also leave it stored with air so if you need to take it to your car or use it late at night you can. You can also use small air tools, drills, grinders and spray guns. Some air tools need oil but you can get and oil fitting if req.
If you get one oof those water jet things you can soak a cat at 50ft
Fun
