Those Cree / Ultraf...
[Closed] Those Cree / Ultrafire 'maglight' style torches on eBay... any use?
[#2653121]
Looking for something helmet mounted to compliment my cheap-as-chips Magicshine '900' lumen handlebar mounted thingy...
The above '200' lumen eBay torches seem like they might be alright - when used with a few bits of velcro etc. to hold in place.
What are people's experiences?
Posted : 12/04/2011 9:41 am
I've got 2 - the lightweight one:
http://www.dealextreme.com/details.dx/sku.15335
and a slightly heavier one:
http://www.dealextreme.com/details.dx/sku.33550
I've settled on using the heavier one. The increased power and flood makes a lot of difference.
I bought a helmet mount at the same time, but ended up just using the velcro straps from it, as they held the torch closer to the helmet, reducing the weighty feel.
I think it's absolutely perfect. One battery is always enough if you turn it off for the less technical bits.
Some links to the other bits and bobs:
http://www.dealextreme.com/details.dx/sku.6105
http://www.dealextreme.com/details.dx/sku.12000
http://www.dealextreme.com/details.dx/sku.20392
(there are a few other batteries, but these have been great for me).
Posted : 12/04/2011 9:49 am
If you want something that runs on AA's:
[url= http://www.dealextreme.com/p/ultrafire-wf-606a-cree-q5-wc-230-lumen-led-flashlight-with-extension-tube-1-cr2-2-aa-14909 ]http://www.dealextreme.com/p/ultrafire-wf-606a-cree-q5-wc-230-lumen-led-flashlight-with-extension-tube-1-cr2-2-aa-14909[/url]
Posted : 12/04/2011 10:10 am
Sounds great! but... how long does this sort of stuff take to turn up from DX these days?
(Due to general impatience and a lack of planning, I always seem to need this stuff asap!)
Posted : 12/04/2011 10:42 am
If I make a substantial order (a couple of torches and the charging gear), then it takes < 2 weeks. But a single cheap item can take 4+ weeks.
If in a rush, you can probably find the same items on ebay from uk sellers for a bit more cash.
Posted : 12/04/2011 10:52 am
I'm also using the "heavier one" from post above helmet mounted. Does a superb job in conjunction with a P7 on the bars (same emitter as your Magicshine but in torch format) and plenty enough runtime for an after-work ride. Not much use if you're doing a 24hr event, but then you knew that already. Highly recommended.
Posted : 12/04/2011 10:54 am
Get a torch with an XM-L emitter in it. Great value and performance but as with anything cheaper the build quality won't compare to Exposure, Hope etc
Posted : 12/04/2011 11:48 am
