Thomson layback pos...
[Closed] Thomson layback post wont let saddle lie flat
Hello,
I've put a Thomson layback post on my zesty, and I can get the saddle to lay flat but the clamp at the back won't fully close... can anyone run their layback set at the last degree marked on the post? If so.. how?
Confused. To the max.
Ricks
Posted : 04/11/2010 1:09 am
Have you got the top part of the clamp back to front?
Posted : 04/11/2010 1:21 am
I was just about to do the same on my zesty, can you let us know if it is the clamp back to front. Assume it's a fizik gobi saddle? Thanks in advance.
Posted : 04/11/2010 8:40 am
I have the same problem with thomson layback posts, the clamp design is the same as the inline posts but the bend means the available range of saddle angles is tilted backwards.
Posted : 04/11/2010 8:52 am
