No worse than my year old pro 2
No worse than hope,easton,crank bros etc or any freehub body made from aluminium.
My Pro2 was similar - just take the high spots off with a small file & It'll be fine.
Thats what happens to aluminium freehub bodies. Doesnt matter what make it is.
More info required I think.
How old, how much use, etc.
18 months old. Not ridden that much as 70% of the time I prefer my HT.
Are you wearing a shell suit?
No. Poly hiking truggers
Blue cheese is too soft.
You should have used a mature cheddar.
dammit....dammit....dammit ๐ฟ
That's nothing. Alu freehub bodies do it. It's basically a cosmetic issue.
You should have used [s]a mature cheddar.[/s] parmesan
SRAM PG 990 Cassette. Problem solved.
" It's basically a cosmetic issue"
K. I'll file off the burrs and continue
K. I'll file off the burrs and continue.
No. He meant your trousers...
;op
Are you using a cassette without a sprocket carrier? i.e. anything other than Sram990/XT/XTR? SLX and other SRAM cassettes have too many individual cogs for aluminium freehubs to handle without scoring.
As said, that happens to everything. I even replaced a King one after about 4-5 years of use a few years ago as it got so bad the cassette wouldn't stay tight.
GB
DT seem a little tougher but Superstar ones are no better/worse than Pro 2s. Steel cassette meets soft alu freehub body, only going to end one way. Tidy it up and forget about it. A cassette with a carrier like XT, SLX, 990 etc will reduce the effect but it'll still happen on the loose cogs.
Shame no one bar shimano properly addresses this issue.
A steel insert on the leading edge of some splines would do it (or deeper splines like campag,)
when mine got too bad. I replaced it with the steel bodied version.
Exactly what cynic-al said, why oh why can't all the companys making alloy freehub bodys let in a steel strip on 3 or 4 of the splines problem solved and wouldn't add any noticable weight and it wouldn't take me 20 mins to get my cassette off.
cynic-al - MemberShame no one bar shimano properly addresses this issue.
American Classic have a nifty insert thing on some of theirs, best of both worlds...
TBH I reckon nobody else does it like Shimano because a Pro 2 with a steel freehub weighs about the same as an XT hub- people buy lightness then complain later about durability but they'll still buy lightness next time.
Exactly Northy.
It beggars belief to me that Hope lack mechanical sympathy in this way.
It's the customer sympathy that's more lacking tbh, their way of dealing with it is to put a little bit of paper in the box that says "Fahgeddaboudit, it's only cosmetic". And to tell us we have to use XT or higher but it's absolutely fine for Orange to fit deore.
You can use a chain whip to turn the cassette anti clockwise Somtimes to release it a little from the burs rather than just beat it off.
Old hope Ti hub body's also used to have the little label about Useing xt or xtr and used to mark up in much the same way.
Just think of the hub body as a service item , when it's buggered totally replace it
what you need is an all in one cassette and freehub.... ๐
Mmmm can't wait for the hope one to be released. 9th bottom cog I need a moment lol
Have a look at a Campag cassette hub, much deeper splines so the load is spread far better.
looks fine
Mrmo, did you read the second part of Al's post where he mentions Campag!
Shimano tried when they first did 10 speed, but people moaned that you couldn't fit 9 speed cassettes to their 10 speed hubs, so they gave up!
njee20, no i read northwind's quoting of Al's post, that'll teach me for not reading the whole thread...
cynic-al - Member
Shame no one bar shimano properly addresses this issue.A steel insert on the leading edge of some splines would do it (or deeper splines like campag,)
It's apparently because American Classic have a patent on the steel insert (according to Brant)
[url= http://singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144292 ]http://singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144292[/url]
[url= http://singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144593 ]http://singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144593[/url]
Interesting, I thought of doing that to the only aluminum freehub I had but then sold it for other reasons. I was gonna file a bit off then araldite in and file down spoke sections.
