Think I've tur...
[Closed] Think I've turned my brand new carbon bar into a £100 ornament!
 S_J
Not paying attention and have overtightened a stem bolt whilst installing a new Easton EC70 carbon riser bar! Aaarggghh!. Set up my torque wrench wrong and heard the dreaded crack. Cant see any obvious damage but there are some small indents where the lower stem bolts have pinched. Do I risk riding it or is it destined for some catastrophic failure!
Posted : 05/09/2010 10:22 am
If you heard a crack, yep it's ****ed 😥
Posted : 05/09/2010 10:24 am
 IA
Bin it.
Posted : 05/09/2010 10:27 am
Bin now or hospital later?
Posted : 05/09/2010 10:37 am
Cut it into 3 or 4 lengths and make a wind chime.
Posted : 05/09/2010 10:40 am
the noise was your wrench reaching the torque! well we can only wish!
be honest and tell the shop/distributor what has happened. you might be lucky and get the option of buying another at a crash replacement/trade price.
Posted : 05/09/2010 10:46 am
What Martin said. Torque wrenches, eh?
Posted : 05/09/2010 10:48 am
I still can't believe people use something seemingly so delicate on a bike that gets (or should get) thrashed off road!
Posted : 05/09/2010 12:10 pm
I agree, and as for F1 cars and supercars being made of the stuff and getting thrashed at 200+mph, why would they do that!! 🙄
Posted : 05/09/2010 12:13 pm
Oh well.
Posted : 05/09/2010 12:27 pm
i rock dropped on to a pair of ritchy WCS i had whilst in the alps. a few deep gouges appeared, and i remembered why i vowed never to use carbon again. my superstar carbon post got squashed a couple of years back, and another carbon bar developed blister like things near the clamp. for me, its just something to worry about, with no real benefit (that i can find).
Posted : 05/09/2010 12:34 pm
 tron
Because F1 has a practically bottomless pit of cash, so it doesn't matter if a wishbone is binned after every race?
As for supercars, the carbon is mostly used in places where it shouldn't get a battering, and again, the maintenance schedule is way beyond what a bike will get.
Posted : 05/09/2010 12:42 pm
 LHS
Bin them, seriously don't take the risk, sorry to hear your mistake.
As for those that question carbon fibres strength, better not get on any aircraft - Carbon wings, fuel pipes, transmission shafts..... the list goes on. Safety critical components tested to the life of the aircraft.
Posted : 05/09/2010 12:56 pm
 tron
And again, not on a maintenance and inspection schedule anything like that of a bicycle. Any impact on any part of the aeroplane and they'll be giving it a serious inspection, and possibly replacing it.
Posted : 05/09/2010 12:58 pm
 juan
Well if carbone is sooo super good off road, why MX bikes (with almost bottom less money pit) aren't made of the stuff?
I know some people that manage to break anything (including a race face turbine crank) have used carbon bars for years with no problems.
But I just cant. That's it call it irrational fear, I just cant. And the fact that easton don't produce any motorbike related product tell me something.
Posted : 05/09/2010 12:59 pm
if you didnt rely on the torque wrench so much then it wouldnt have happened
did you not think "hmmm im using a bit much pressure here i should maybe check"
or just racked it up waiting on the click from the torque wrench
most home mechanics torque wrenches are about as much use as a chocolate fireguard anyway.
by all means use em but relying on them solely is fools folly
Posted : 05/09/2010 1:00 pm
Classifieds
Posted : 05/09/2010 1:02 pm
Wot trail rat said.....
Posted : 05/09/2010 1:07 pm
What you could do is, ride on it til it breaks in half- which won't take long at all, it's ****ed, sorry- then post it on Bustedcarbon so people can say "Oh, carbon fibre's so weak!"
" trail_rat - Member
"if you didnt rely on the torque wrench so much then it wouldnt have happened did you not think "hmmm im using a bit much pressure here i should maybe check"
Sounds harsh but it's 100% true.
Posted : 05/09/2010 1:36 pm
Windsurf masts are made of carbon and the accepted way of clamping the boom so it doesn't slip is to tighten it until you hear the creak.
They handle a lot of load and seem to last for ever.
Posted : 05/09/2010 1:41 pm
"Windsurf masts are made of carbon and the accepted way of clamping the boom so it doesn't slip is to tighten it until you hear the creak.
They handle a lot of load and seem to last for everbigjohn
I have been sailing for years and have never heard that , and I havent had problems with booms slipping for at least 15 plus years. Carbon is great but fragile if abused
Posted : 05/09/2010 2:02 pm
Not had a problem using carbon bars either and they take quite a bit of abuse. My mates carbon seatpost has a crack in it near the clamp, he's been riding it like that for months without any bother
Posted : 05/09/2010 2:08 pm
Brave or foolish?
Posted : 05/09/2010 2:16 pm
Posted : 05/09/2010 4:32 pm
crack or creak?
Posted : 05/09/2010 6:39 pm
Before you bin them, I know that Easton can check them for you.
Posted : 05/09/2010 6:47 pm
juan - Member
Don't want to completely piss on your bonfire but, mx bikes don't use carbon frames because there is production rules in both FIM and AMA sanctioned races. The bikes have to start from a production chassis (these are later modified to a degree that makes them so far removed from the original that makes you question the rule but hey!) The mx community was in uproar when the new YZ450 came to over £7000 so carbon parts won't be appearing any time soon (not to mention that KTM, Husqvarna and others still use steel frames and they are still a comparable weight.) Also actual weight weight isn't as much of an issue as perceived weight the new KTM350 is actually heavier than some of the 450s (Honda being the lightest) but it rides lighter due to it's lower displacement/ less inertia from the engine (hence why a 250f is less tiring than a 450 despite their only being a few kilos difference.) Finally Easton do produce a set of motocross bars, corresponding clamps, grips and grip doughnuts. They are notably used by star racing Yamaha in the US and Mat Rebaud for FMX. They aren't carbon though. Carbon is used quite extensively in high end after-market exhaust systems (Leo Vince, Akrapovic etc) as is titanium, this is probably more for the bling factor than performance (as is the exhaust usually!) [img] [/img]
Iain
Posted : 05/09/2010 7:07 pm
 hora
Are your pinch bolts quite 'dry'?
I have a Thomson stem and ALWAYS get this dry crack noise when tightening the bolts back up (alu bars). Doesn't necessarily mean you've cracked your bar IMO.
Posted : 05/09/2010 7:12 pm
 S_J
Bolts are pretty dry tbh and I'm not completely convinced I've written it off. I'm just being super cautious because it's carbon. As I say I can't see any significant damage, but again carbon doesn't always show damage before it fails. The torque wench was set to 5nm but I didn't realise it's not effective until 10 - stupid mistake i know! not sure whether this is enough to crack a decent quality bar?? I didn't even get to the click because I was suspicious...
Posted : 05/09/2010 9:09 pm
Why don't you clamp them in again, grab hold and try and break them. If they withstand that then ride them.
Posted : 05/09/2010 9:12 pm
 nuke
[i]I have a Thomson stem and ALWAYS get this dry crack noise when tightening the bolts back up (alu bars).[/i]
Bit of copper slip on the bolts solves that...always done that on my Thomson stems.
"there are some small indents where the lower stem bolts have pinched" doesn't sound good at all. But 10nm isn't so much that I'd be assuming they're dead, your earlier post made it sound like they'd been massively overtorqued.
Posted : 05/09/2010 9:15 pm
 br
Buy one of these:
http://www.winstanleysbikes.co.uk/product/27096/Ritchey_5Nm_Torque_Key
And tbh I find that I don't tighten enough to hear/feel the 'click'.
Posted : 05/09/2010 9:20 pm
WTF does anyone need a torque wrench for assembling anything on a bike. A bit of common sense and mechanical sympathy will get you a long way, well at least a lot further than relying on a uncalibrated or badly set up torque wrench.
Posted : 05/09/2010 9:24 pm
 S_J
I always normally do these sort of things on 'feel' this time I thought I'd try and do if 'properly' oh well, I'll se how I get on. If I post a picture of me with half a carbon handlebar sticking out my head you'll know it's not gone well.... Seems like a sound investment that torque key
Posted : 05/09/2010 10:05 pm
Do a search for Carbon bars on SDH - there's a recent thread on it with some input from an F1 Materials Technologist - if he says don't use carbon bars (and he does) I wouldn't. It's the wrong applications for the material and simply not worth the 50? gramme saving over a decent ali bar.
Posted : 05/09/2010 10:38 pm
 hora
Ah, well lets face it. Its on thing that if it fails you are most certainly falling off your bike asap at any speed.
Posted : 06/09/2010 11:11 am
I've donr this in the past, brand new carbon bar - crack! Ended up with indents as you describe.
Bin them and never go near carbon bars again! well thats what I did
Posted : 06/09/2010 11:23 am
EC90 = 135g
EA70 = 265g
Claimed weights.. weightweenies would give a better idea.
So it's a reasonable weight saving. I've used USE Atoms for a few years now and they weren't installed with a torque wrench or owt. Not recommending that, but the bars are pretty tough.
That said, the method and result of possible failure has made me go back to Thomson seatposts off road. Not sure how you judge the torque on a QR??
Posted : 06/09/2010 11:24 am
PS - I wouldn't use them if I'd heard them go crack. No sir.
[i]It's the wrong applications for the material [/i]
Really? I'll bet that'll come as a surprise to Easton, who've been making carbon bars for at least a decade or more....
But hey, some bloke on a forum says something that reinforces your prejudice, so that's so much more weighty an opinion isn't it?
There was an article in one of the US mags a while back- I saw it linked from Pinkbike but I can't find it now- where an Easton engineer discussed the failure modes and strengths and weaknesses of their various bars and concluded that the least suitable material they use in bars is aluminium. He also commented that they'd tried to make an aluminium bar as strong as their carbon DH bar but couldn't make it come in under 500 grams. Though that was a couple of years old I think so both the carbon and alu bars have changed a little since.
Posted : 06/09/2010 2:18 pm
Meanwhile many of us are riding around on rigid carbon forks....
Posted : 06/09/2010 5:56 pm
 7hz
Tip I use - tighten up using the short end of the allen key, this makes it much harder to overtighten.
Also, I don't see the need to crank on the handlebars, I always am very gentle with everything to do with the handlebar (clamp, levers) and don't find it moves at all.
SDH = .southerndownhill.com? "You are not allowed to search for posts in this forum. Please login below or register an account with SDH."
What's the guys name? "F1 Materials Technologist", how much does he know about bike handlebars? Sounds like a 14 year old winding people up TBH.
Posted : 06/09/2010 7:25 pm
 tron
[url= http://www.southerndownhill.com/index2.php?option=com_smf&Itemid=0&topic=112251.msg1005526 ]http://www.southerndownhill.com/index2.php?option=com_smf&Itemid=0&topic=112251.msg1005526[/url]
Reply #21.
I love how people will post "Oh yeah, they use it in X environment, so it'll be fine", normally something not even vaguely comparable to bike handlebar use due to completely different environmental, service and inspection factors. Then a person who actually who knows about it is instantly dismissed as probably being 14, and even if he isn't, not an expert in handlebars 😆
Posted : 06/09/2010 8:10 pm
Easton Warranty on Aluminium bars = 5 years
Easton Warranty on Carbon bars?
Lifetime
Posted : 06/09/2010 9:57 pm
Get an aluminium bar and don't worry about mountain bike forums? Problem solved?
Posted : 06/09/2010 10:21 pm
Easton Warranty on Carbon bars? = Lifetime
Easton Warranty for overtightening = Zilch
Posted : 06/09/2010 10:29 pm
 7hz
I love how people quote other unknown posters on other internet forums with dodgy sounding credentials that rubbish a technology that is proven usable within the parameters of realism and expectation for over a decade and manufactured by very reputable manufacturers and used by a large number of people without problem, and back that up with a massive warranty.
Yes if you are throwing yourself down mountains then sometimes sh*t will happen, but usually there are mitigating factors such as previous crashes etc.
Don't kid yourself that aluminium bars are in any way shape or form fail-safe for this role.
Posted : 06/09/2010 11:23 pm
Yep, only on my road bike though (I think)!
I'll be honest and say that I clearly don't have a clue about the strength properties of carbon vs aluminium etc and that I just have in my mind that carbon = weak. If it requires near enough treading on eggshells to fit the component, it's not something I'd fancy on a bike that goes off jumps and stuff.
Posted : 06/09/2010 11:37 pm
 tron
Even if the guy were some loon in his mum's attic, it doesn't negate that carbon fibre is rarely used in such a hostile environment as mountain biking.
I suspect the nature of carbon makes providing a lifetime warranty fairly low cost. Damage to carbon can often be invisible, and failures sudden, so very often the advice given is replace any carbon bits as soon as there's visible damage or after a big stack. That leaves a lot of carbon bits that are damaged to the point of uselessness, without being a warranty issue.
Posted : 07/09/2010 8:31 am
