Thin walled 8mm soc...
[Closed] Thin walled 8mm socket anywhere?
Evening,
Looking for a thin walled 8mm socket for my Manitou forks. Anything available that’s cheaper than buying a whole bike specific tool set?
Chris
Posted : 19/01/2022 11:16 pm
Get a cheap one and turn it down on a grinder
Posted : 19/01/2022 11:45 pm
Box spanners will probably do you, so long as the torque isnt excessive. Cheap as chips too.
Posted : 20/01/2022 12:01 am
Thanks both. I had ground down a normal socket but managed to crack it on first use.
Will try a box spanner and see how it goes.
Posted : 20/01/2022 8:50 am
I tend to find that 12 point sockets are slightly thinner than 6 point sockets. Worth a look maybe?
Posted : 20/01/2022 9:18 am
if you hold it in the drill and spin it round it might help a bit
Posted : 20/01/2022 9:24 am
Surprised that it needed that much torque
Posted : 20/01/2022 9:34 am
Not a specific recommendation on this specific one but I found the cheap bit sockets with a hex shank are mostly thin walled. I use these for stuff like pedals where there is a specific thin walled socket or tool sold.
socket
Posted : 20/01/2022 9:42 am
I bought the service kit (but sold it with the forks, sorry!) and it was very thin-walled.
If you can find someone with a metal lathe it's a simple job to turn one down to size. See if you can find a friendly local model engineering group.
Posted : 20/01/2022 10:56 am
i tried a hope pedal socket... gnats whisker too large
ended up buying the manitou kit just for lack of drama
Posted : 20/01/2022 11:01 am
Try a set of monobloc tap box spanners - they start at 8mm and go up to 12/13mm, cost about £5-6 from Screwfix
Posted : 20/01/2022 11:03 am
Is a Shimano pedal tool any use?
That's really thin.
Edit just seen the price..you can borrow mine if you're near Epsom.
Posted : 20/01/2022 11:04 am
Thanks all. Yeah, I was surprised I cracked the socket but guess that my 'engineering' skills were perhaps the problem here and I didn't grind it down quite evenly.
Found some box spanners on amazon cheap so will try them.
Posted : 20/01/2022 11:27 am
