Thick/thin singlesp...
[Closed] Thick/thin singlespeed cogs? Why?
Don't get me wrong I like the aesthetics and the wide base to the [url= http://www.absoluteblack.cc/cogs.html ]AB cogs[/url] but not sure what benefit there could be?
Oh hang on would it be of benefit if you were singlespeeding in a normal frame with a tensioner?
Posted : 06/06/2014 5:23 pm
I was thinking that. If the chain is tight enough there really isn't a need for it.
Posted : 06/06/2014 5:30 pm
Its for those who forget your supposed to tension the chain once in a while
Posted : 06/06/2014 5:39 pm
Kinda pointless? 2x as expensive for something that’ll last a fraction of the time. And an expensive mechanical solution for a niche of singlespeeders who are adverse to spending money maintaining the only maintenance task on their bike?
The only niche it’d work on is non SS frames and not using a tensioner and only then in the minority where the ‘magic ratio’ falls on an even number and didnt need a half link!
Posted : 06/06/2014 5:41 pm
About as much use as t**s on a fish.
Nice bit of machining though.
Posted : 06/06/2014 5:43 pm
I likes the disclaimer 🙂
If you weigh over 100kg or ride your single speed everyday, best to choose the steel option which is coming soon.
Posted : 06/06/2014 6:06 pm
In the case of the AB one I'm going to say "because it looks freaking awesome".
Posted : 06/06/2014 6:11 pm
I know at least one singlespeeder with a Ti frame that's so flexy on the back end that it keeps throwing the chain when he really puts the power down.
It'd work a treat for him.
Posted : 06/06/2014 6:45 pm
For pimp value its pretty good, otherwise pointless.
Never lost a chain riding singlespeed either on of off road and even when riding geared the bulk of the times I have dropped a chain its been at the front/crank end.
Posted : 06/06/2014 7:13 pm
I've lost a chain off the back when a bit loose.
Posted : 06/06/2014 7:51 pm
