Them adapter things...
[Closed] Them adapter things that go round a brake hose to make it fit the stops
You know what I mean? Those little bit sof split plastic that go round a brake hose then push into the stop in the frame to hold it in place?
Know where I can get some or what they are called so I can google?
Posted : 03/11/2009 2:17 pm
 nbt
Ferrules or cable end caps
http://www.parker-international.co.uk/5118/Shimano-SP40-41-Outer-Cable-Casing-Caps.html
Posted : 03/11/2009 2:21 pm
I know what you mean but I can never find them so I use zip ties.
Posted : 03/11/2009 2:28 pm
No not them. I know they are ferrules.
What I mean is a plastic sleeve that goes round a (hydraulic) brake hose to make it a bit fatter so that it fits in the stop (usually the stops next to the gear cable ones on the top tube) on a frame.
They usually have a split down one side so you can get them round the hose and a small lip at one end to stop them sliding all the way through the stop.
Posted : 03/11/2009 2:29 pm
Ah, not what I was thinking of then, I was thinking of these -
I used to have to run the ones you are talking about on my old Cannondale and I got some spares from Phil Corley in Milton Keynes.
Posted : 03/11/2009 2:32 pm
I had 'em on a Cannondale too and I need a couple for my nephews Kona....
I could bodge with insulation tape or just cable tie them but I reckon they must be available and surely only pence?
Posted : 03/11/2009 2:36 pm
Jagwire do them
I did buy some but I can't remember where from
http://www.jagwireusa.com/index.php/products/mountain/484
Posted : 03/11/2009 2:42 pm
Do you mean these?
MPart: Top Tube Cable Guide Set
http://www.wiggle.co.uk/p/cycle/7/MPart_Top_Tube_Cable_Guide_Set/5300005193/
Posted : 03/11/2009 2:46 pm
MP if you find any let us know as i reckon i'm going to need some on my frame i just bought
Posted : 03/11/2009 2:47 pm
He means these I think
Posted : 03/11/2009 2:49 pm
Uplink is right.
Google / eBay is not helping me find any to buy though.....
Posted : 03/11/2009 3:02 pm
Jagwire part number: DCA072
I only need a couple of the bl**dy things.
Posted : 03/11/2009 3:03 pm
WooHoo. I have a couple of those sat on the desk in front of me, looking for a good home.
Must be worth more than what RBS is worth!!! Who wants them. First come, first serve. Mail me.
Posted : 03/11/2009 3:54 pm
Nobody want them? Oh well, back in the parts box!
Posted : 03/11/2009 4:36 pm
Me!YGM!
Posted : 03/11/2009 6:16 pm
Instead as per someone's suggestion ages ago
http://www.singletrackworld.com/forum/topic/how-do-you-secure-the-gear-cable-in-the-guide-hoops
I used some carefully squirted silicone seal into the guides, poked a small hole in it, let it set and then routed the cable through the (tight fit) hole. Works well to stop slap/rattle but it does slip through.
Posted : 03/11/2009 7:50 pm
Noahs Ark have the 'dale ones in the workshop which they will sell. Not online though. Give them a call.
Posted : 03/11/2009 7:57 pm
found some!!!!
[url= http://www.cannondale-parts.de/epages/61764971.sf/en_US/?ViewAction=View&ObjectID=1203098 ]here[/url]
Posted : 16/11/2009 10:30 pm
