The poll about elec...
[Closed] The poll about electric gears
Interesting point mansonsoul.
Good technology should simplify rather than complicate our lives. I'd probably like to see a system that can be built ground up by the user, with energy generated from some kind of hub dynamo before it would properly interest me
Posted : 02/03/2012 9:10 am
Anyway, back to hydraulic shifting, it's been done (and apparently works very well):
http://www.gizmag.com/ag-e-hydraulic-shifting-for-mountain-bikes/18450/
Posted : 02/03/2012 9:27 am
As soon as parlee route the z5 sl properly for the electronic system, I'll be spaffing a small fortune equipping myself with one.
Posted : 02/03/2012 9:37 am
 ojom
Jeremy- shimano had similar reservations about alfine off road. How's yours getting on.
They are just being their usual cautious self. They never play up the kit they make. They state facts and are quite grounded. You know they will get it right first time - it's what they are best at.
Posted : 02/03/2012 9:43 am
rapid rise?
Posted : 02/03/2012 9:44 am
It is simpler. Less maintenance, internal routing of cables so cleaner lines to the bike.
The [b]only[/b] downside to electronic shifting is the high price. Campag's new Super Record EPS is £3500! 😯
Di2 is cheaper but that was never intended as mass production so still high price; all the Dura Ace Di2 was made in small batches and intended for pro use. Now they've refined the process, simplified things a bit and introduced Ultegra Di2 (which IS mass produced) and the price will drop.
This basic argument has been the same every single time something new has come along:
friction shift -> indexed.
7sp -> 8sp
8sp -> 9sp
downtube shifters -> integrated
Every time the wailing and gnashing of teeth, the cries of it won't work, it'll get clogged with mud, it's too complicated, too heavy, unnecessary blah blah, always from people who've never actually tried it out.
Meanwhile the people actually using it just go
"yep, it's fine, thanks very much"
Posted : 02/03/2012 9:46 am
You are rather more optimistic than shimanos press officer crazy legs.
These parts are a lot more expensive to replace and repair and that's definitely a concern plus the level of potential contamination steps it up a notch. It makes hypothetical sense but to make the jump into real world execution is a whole other issue."
Posted : 02/03/2012 9:48 am
[quote=TJ said]no I have not - however neither have you ridden it in mountainbiking conditions over a number of years
[quote=TJ also said] 20 yr old mech on my bike that works fine
20 years!?,mountainbiking conditions? are you sure you're not just riding your bike around the park?
[quote=mansonsoul said]Do we want to retain that unrivalled sense of mastery over our machines that we currently have
Have you never taken a shifter to bits? 😯
Posted : 02/03/2012 10:00 am
The electronic gears discussion is the same as disc brakes.
People used to say they were
- too complex
- bound to be unreliable
- heavier
- no need for them as V brakes work well
- too expensive
Yet they are now usually easily affordable, fit and forget and on most bikes - all mid to high end bikes.
Electronic shifting is bound to go the same way - isn't it ?
Posted : 02/03/2012 10:17 am
TJ - I know it's a bit OT, but why have you repeated the same quote three times now...?
Genuinely curious.
Posted : 02/03/2012 10:25 am
Yes I have. It can be done, carefully. But electronics and batteries are somewhat different.
we have all taken them to bits but have you rebuilt it 😉
Posted : 02/03/2012 10:28 am
What's with the rapid rise bashing? It's brilliant.
Every girl I know that struggles with left and right loves it (and I). It makes changing gears simple, always push up with the thumb to go up and the opposite to go down.
Plus it means I have have my alfine bikes shifting the same as all my other bikes (except the other way around obviously).
Brilliant!
Oh and I was pissing my sides at the constant questions at how much it cost..
Posted : 02/03/2012 10:29 am
Well like it or not electronic is coming to mountain biking and personally i am looking forward to it, i have heard as others may have that eletronic XTR is on the way and maybe within 2012, and i have heard from a source in the know that shimano have already planned electronic XTR, XT, STX and deore within the next seven or eight years, As people have said in this thread shimano generaly do good things and as of yet i havn't heard of any problem with dura ace or ultegra di2, as for rapid rise it wasn't a problem with the product as it worked fine the general public just didn't take to the idea.
As for the battery v's dynamo WTF you know how heavy those hubs are don't you and the battery lasts 6-8 months and only takes 2-3 hours to charge and as someone else commented if you ignor the few hudred miles worth of low batt warning well you deserve to be stuck in that huge gear all the way home. ROLL ON XTR DI2.
Posted : 02/03/2012 10:59 pm
How long then, before it becomes the norm? Not just fashionable but affordably better than mechanical?
Posted : 02/03/2012 11:05 pm
its quite simple, cable brakes where awful, and early discs where an affordable 'game changer'
modern cable operated transmission is so slick and reliable
Also, i enjoy being out on my bike to get away from the total electronic exposure i get at work & home
I'm open to evolution, but i'll leave it to the XTR crowd
Posted : 02/03/2012 11:37 pm
Thank you aracer. There was also a system called s.a.f.e. (scott Allen fife enterprises I think) that would retro fit to existing shifters and mechs. As I remember, the only failing was that it was way ahead of its time. I'd love someone to reserrect that system.
Posted : 03/03/2012 12:17 am
The idea of electronic shifting? Brilliant.
Having said that, I haven't had to adjust the cable tension of my X9 setup in months. My Shimano bikes need a little more tweaking, but it's instinctive and takes a minor twiddle before it's sorted for another few months. I know electronic shifting will need no adjustment and will sort out the annoying chain rubs in certain gears. I also know that electronic gear shifting will be consistent, day or night and come rain or shine.
But it won't be night and day like switching from V-brakes to hydraulic discs was. It won't be the revelation that going fully rigid to a decent oil dampened fork was either. The cost is going to be prohibitive for a while and I daresay that fitting a full outer to your cable shift would be a far more cost effective upgrade.
Posted : 03/03/2012 12:29 am
Page 3 / 3
