That new 29er Hardt...
[Closed] That new 29er Hardtail in the px/on one news letter
 lcj
The new [insert name here] looks just what I'm after. Except for the boost bit. Please don't do that Brant, or at least offer a non-boost version so that decent kit that just doesn't happen to be fashionable can be kept going!
And agreed on the raw finish. Please do do that.
Thank you. Please.
Posted : 02/04/2019 11:14 pm
Non boost for me, colour I don't care, I'll have one of them.
Posted : 02/04/2019 11:17 pm
Raw is fine with me
Posted : 02/04/2019 11:50 pm
Need to buy wheel sets.
Hope I'm not prying too much into insider stuff that you don't want to reveal (do say, if so) but is boost that much of a benefit when buying wheelsets! The parts at retail still seem to carry a premium over non boost, for instance
If you want to experiment, I'd go for a set of those forks in non-boost and about 490mm a-c. Much nicer looking than what's out there at the moment.
Posted : 03/04/2019 12:01 am
cromolyolly
It would be interesting to know how much difference there is in the raw material price
It won't just be material costs, though. Some of these are also harder to work with. They're also just used less which means less expertise out there to do things for you. And I suspect that to get the best out of them- and why do it, if you don't plan to- then you need to sweat the design a lot more which probably means more actual prototypes which is time and money
Also frankly people will have higher expectations of magic steel. Not all of those will be reasonable, or even realistic, or really based in fact at all but still. If you buy a cromo frame and the finish turns out to be weak, or every ride doesn't inspire you to write poetry, you're less likely to lose your shit about it than if you bought an 853 ego chariot.
Posted : 03/04/2019 2:11 am
In very much with the non boost argument too.
Loads of well priced (new/ used) non boost stuff around making the build a great value/budget option.... Though a bling build is still an option of course!
Posted : 03/04/2019 2:40 am
Shouldn't boost be quite replacable-dropoutable? Which is something On One have a bit of history with, even if they kind of sucked at it.
Posted : 03/04/2019 3:02 am
It won’t just be material costs, though
Yes, Fair point. Although I'd have thought that given there is a relatively small number of frame makers in Taiwan, they must be pretty experienced at cranking out just about any material you care to mention. Plus their production engineering types must be able to give good advice. All the other costs would be spread across the product run so wouldn't add up to a huge amount per unit - I'd guess we were talking 10s of pounds per unit not 100s.
Your last point is very likely the biggest cost. Which I tend to lump in with marketing. Use a higher grade because it's more marketable (to a certain segment) so you can mark up a bigger margin, but using the higher grade puts up your cost so you have to markup even more to maintain the margin.
Posted : 03/04/2019 4:00 am
All the other costs would be spread across the product run so wouldn’t add up to a huge amount per unit – I’d guess we were talking 10s of pounds per unit not 100s.
About 15 years ago, I got talking to an American guy who had a small company selling hardtails that his partner in Eastern Europe produced. His aluminium frames were in the $1000 range, IIRC, but he reckoned that Giant could produce an aluminium frame for about $50. Obviously, that will vary a lot because the lightweight aluminium frames will be trickier to weld and heat-treat and carbon frames will require a lot of labour, but his point was that having a high-tech factory set up to churn out millions of frames makes it impossible for small volume makers to compete on price because of labour costs.
Posted : 03/04/2019 4:15 am
I don't like to say it but I really can't see a good reason to not go boost on a frame these days. Same as most of the nay sayers I've got a garage full of non boost wheels but, making them "boost" is a few pounds of adapter, you can't do that the other way around. Boost is here and current ish, non-boost is old hat, offers no benefit over boost and unlike 148 does limit your choices.
Posted : 03/04/2019 4:36 am
I may be way off but I thought that was an rare in small frame outfits. I thought most had them made in the same factories in Taiwan that giant/trek/specialized use, or the next tier or two down in size (like sick bikes were doing, in theory). I thought genuinely boutique frame makers were rare. So that should change the cost structure significantly. Obviously you would get the kind if deals the truly big outfits will because you can't offer the volume but you can benefit from their ability to build efficiently.
Posted : 03/04/2019 8:18 am
My preference on a new frame in order.
1) changeable drop outs
2) boost drop outs, it future proofs the frame. Boost kits are available.
3) 142 drop out.
Please don't use any funny standard like qr boost or boost plus
Posted : 03/04/2019 9:39 am
 lcj
making them “boost” is a few pounds of adapter
Assuming that such an adaptor is available - not so with Hope Pro 2, for instance?
Posted : 03/04/2019 9:46 am
Assuming that such an adaptor is available – not so with Hope Pro 2, for instance?
Kits are available that will work for pretty much any hub that is 142mm, they usually consist of either 2 x 3mm or 1 x 6mm spacers for the axle and approproate spacer for the disc, I am running this exact setup on a 142mm SRAM X0 hub in my Genesis Tarn boost frame with no issues.
Posted : 03/04/2019 12:07 pm
Take my money.
Posted : 03/04/2019 12:11 pm
Looks like what I am after - something reasonably similar to the Pinnacle Ramin 3+ but in steel - 29er/650B+ compatible, lots of bottle bosses on frame and fork. EBB would be nice.
Posted : 03/04/2019 12:32 pm
As far as I know the hope adapter kits work just fine on Pro ii wheels, despite saying pro ii evo and pro 4. They're just spacer kits.
Otherwise there are loads of generic third party ones and even CL can be adapted but you need to adapt them to IS 6 bolt rotors at the same time.
But to brant's question swappable (properly ss-able) would be awesome
Posted : 03/04/2019 2:35 pm
 lcj
Thanks dangeourbrain, that's interesting to know. I was basing my thoughts on a previous STW thread that had concluded they weren't compatible.
Would still rather non-boost though for ease!
Posted : 03/04/2019 4:18 pm
External cable routing, full outer cable runs.
No funny dropouts or EBBs - keep the costs and weight down, minimise potential creaks.
Threaded BB shell, bog standard tapered headtube.
Boost spacing - a subset of people (like me) would be buying one to 'upgrade' from the 26" bikes they're still on, and won't want to buy into a non-boost wheel standard that's already dead and buried.
Do that and I'd buy one. It'd be a cheap, solid, easily maintained, updated, relatively future-proofed version of the 26" bike I'm riding now.
Posted : 03/04/2019 4:30 pm
It’d be a cheap, solid, easily maintained, updated, relatively future-proofed version of the 26″ bike I’m riding now.
That's how I see it - it's like a 90s MTB that's had the good technology added of the last couple of decades added, but none of the extraneous stuff.
Posted : 03/04/2019 4:33 pm
Oh. And Afrika Korps camouflage, please. Failing that, matt grey.
Posted : 03/04/2019 4:36 pm
No funny dropouts or EBBs – keep the costs and weight down, minimise potential creaks.
Boost spacing – a subset of people (like me) would be buying one to ‘upgrade’ from the 26″ bikes they’re still on, and won’t want to buy into a non-boost wheel standard that’s already dead and buried.
Do that and I’d buy one. It’d be a cheap, solid, easily maintained, updated, relatively future-proofed version of the 26″ bike I’m riding now.
Sorted.
(well except for the headtube which is 44mm straight headtube, but yeah)
Posted : 03/04/2019 5:11 pm
Sounds like it'll just be a no-nonsense way into buying a steel frame. Makes perfect sense (if you want to shift units) to make it boost spaced, especially as the adaptor things are so cheap. It IS getting harder to find non boost hub spacing, the market drives it with new bikes, which means cheap sets will come up more and more as folk upgrade too.
Posted : 03/04/2019 5:34 pm
And a proper long headtube in the XL size. Boils my piss when companies don't do that.
Posted : 03/04/2019 5:45 pm
Matt grey sounds nice actually. Or gloss grey, like currently seen on the new Mini/Audi/Skoda ranges..
My final thought on frame, please lower the cable mounting point nearest the headtube, my fork valve caps strike the cable guide on my Ti 29er on full lock, and the tight angle that the cables enter the guide forces the cables tight up against the headtube/lower headset cup.
Posted : 04/04/2019 11:30 am
That looks absolutely ace, any ideas when it'll be available?
Posted : 04/04/2019 5:48 pm
Are we suggesting names still?
then....
Biffins Bridge or The Gooch.
Posted : 04/04/2019 6:14 pm
dangeourbrain
Subscriber
I don’t like to say it but I really can’t see a good reason to not go boost on a frame these days.
I think there's definitely a market for "frames to put my old stuff in that ride like new stuff", and On One are probably quite well placed to capitalise on that with their traditional rep. Whereas the "everything must be the latest and greatest" market are probably less inclined to buy their stuff.
hols2
Member
Maybe, provided the factory was free.
Posted : 04/04/2019 7:03 pm
Sounds ideal for my next bike have a few spare bits but no wheels or forks so boost seems like the best option to me.
Posted : 04/04/2019 7:45 pm
Cant beat a bit of Reynolds 853 for a compliant frame. Lighter and more flexible than 4130cr
Posted : 04/04/2019 8:09 pm
Unless I am mistaken, which is probably the case, there is nothing on the market available as frame only that has:
- Lightweight Alu Frame
- 100-120 fork
- 480-500 reach in XL
- 68 degree head angle
- 29x2.4/6 clearance
- Internal routing (sorry but I like the clean lines)
I hope the new Scandal can be all this... in a clearcoat/ raw kind of way.
EDIT The Nicolai Argon GB maybe.... but by golly do you pay for it.
Posted : 05/04/2019 8:11 am
I think there’s definitely a market for “frames to put my old stuff in that ride like new stuff”,
I agree there is a market but
(a) I personally don't see it being big enough to make it one I'd want to pursue (not least as that is also very often the "I want fantastic but don't want to spend any money" market too). I'm not brant or px/oo though so their opinions may differ.
(b)boost works just fine with a few £ of adapter for almost all 142x12 or 100x15 wheels so the "old stuff" will work just dandy for any one willing to pay £5 per end for some spacers, for those who won't, see my huge generalisation in point (a).
(c) the only kit that can't be adapted to boost is cl rotors and qr* only wheels which won't work with 142 either and building a 135x10 frame these days would be as daft as qr boost or some such silliness.
*other "old" or odd standards such as fat bike hubs are available but not exactly common.
Posted : 06/04/2019 1:07 am
I see your point. But then you're throwing away a perfectly good hub which is probably the biggest proportion of the price of the wheel set.
Reusing an old hope Xc is saving £150 (the cost of the frame) and there is zero need for bolt through stiffness on a hardtail.
My pro2's I can convert. But it's still spending money on something unnecessary when you include the cost of an axle etc.
Posted : 06/04/2019 1:29 pm
In my case, 12 year old Pro IIs, 9mm QR, 36 spokes, built into bomber wheels. Makes no sense cutting the hubs out to bodge them into one of the very limited selection of 36h rims now available. I'd rather keep using them on an appropriate frame. I appreciate that's a specific position to be in, but I think the general point still stands about Boost adaptor kits and buying into an obsolete wheel standard.
Posted : 07/04/2019 9:46 am
widge34
Member
If you use the same diameter tubing with the same wall thickness I'm not sure that's the case.
Posted : 07/04/2019 11:26 am
Brant, will the 29er Scandal (or what ever you call it) be available on pre order? If so, any ideas on when? Thanks
Posted : 07/04/2019 3:33 pm
And will it be single-speedable?
Posted : 10/04/2019 12:33 am
hugo rune
Important question! The very roots of On-One are single speed, so don't abandon it.
It's also useful for geriatric singlespeeders who are going soft and fitting decadently wimpish accessories such as hub gears.
Posted : 10/04/2019 8:47 am
– Lightweight Alu Frame
– 100-120 fork
– 480-500 reach in XL
– 68 degree head angle
– 29×2.4/6 clearance
– Internal routing (sorry but I like the clean lines)
I hope the new Scandal can be all this… in a clearcoat/ raw kind of way.
Whyte have shot themselves in the foot again with selling completes only.
Their 629 & 529 (same frame) have all those covered, plus through axles. Although fantastic price complete, they could be super competitive if they where frame only.
I might get another 529 as a winter hardtail.
Posted : 10/04/2019 10:02 am
great way to add flex and weight to further compromise fitting the wrong size hub into a frame not designed for it though.
Posted : 10/04/2019 10:17 am
Cokie - The Whytes have 66.5 degree head angle and clearance at the rear only for 2.3 (I think). But yes it is annoying they don't sell frames only, I am sure there would be a big market out there, even if they were to price them on the high side compared to their complete builds.
Posted : 10/04/2019 2:50 pm
So Brant - news is pretty slow and the website and FB page have no updates.  Can we get a release date and more details for the steel 29er scandal?  And can I pre-order?  😉
Posted : 23/04/2019 8:12 am
After me..
WHAT DO WE WANT?!
Posted : 24/04/2019 10:18 pm
Content being updated and I think preorder should be open soon.
Posted : 24/04/2019 10:45 pm
The jumping flash looks good.
Brant, any more information about it? Thanks
Posted : 30/04/2019 3:06 pm
Looks like it's going to happen. Just not sure about 26/27.5, disc/canti, repro or homage.
It'll get sorted.
Posted : 30/04/2019 3:16 pm
I can't wait to order a pair of the steel thru axle 29er forks, so I can replace my carbon fork and drastically reduce my fear of sudden death at high speed.
Does anyone have a link to the newsletter that STW have posted today, with all of the new bikes listed?...
EDIT: nevermind found it https://www.on-one.co.uk/on-one-bikes-current-projects
Posted : 01/05/2019 1:53 pm
Not sure if it's been mentioned previously in the thread but will the new Scandal have sliding dropouts for SS?
Posted : 01/05/2019 9:53 pm
@brant. Sure you have better things to do than sit on this forum answering people's random questions and personal requests ... But indulge me a little further ...
The 29er Tinbred ... Roughly when is that due, what are the vital stats, and how much? I think I'm done with my FS experiment and just want a 1-MTB-to-do-it-all in big wheel, Ti, modern geo, wallet-friendly flavour please to sit alongside my excellent Pickenflick! How long will I have to wait ... and how much ££'s do I have to find down the back of the sofa?
Posted : 03/05/2019 1:40 pm
29er Tinbred will be as per big dog.
130mm forked 29er. Takes 2.6in in the rear. Or 2.8B+.
65 head, 75 seat, good reach, four sizes.
I'm looking at doing a more steady away 29er too with like a 100mm 29er fork too.
Price will be like £700 or so.
Posted : 03/05/2019 1:44 pm
I’m looking at doing a more steady away 29er too with like a 100mm 29er fork too.
Fab!
When?
Price of £700? Frame only right? Full build? I'm assuming £1400-1800ish?
Posted : 03/05/2019 2:13 pm
Hmmmm Ti Inbred sounds very interesting, maybe more than the steel doobery that peaked my interest back at the beginning of this thread.
1-MTB-to-do-it-all
Isn't that the sort of thing only someone who is doomed to disappointment would say? Anyone who is likely to find a "one bike to do it all" bike just wants a bike because "all bikes can do it all" surely? The idea any bike might not be all things to all men is iredeemably far into permanent n+1 territory I think.
Posted : 03/05/2019 2:37 pm
Price of £700? Frame only right? Full build? I’m assuming £1400-1800ish?
Yes
Posted : 03/05/2019 2:48 pm
Big Dog does sound good. If it has frame bosses for rack, I can get rid of the gravel commuter too!
Posted : 03/05/2019 3:23 pm
Isn’t that the sort of thing only someone who is doomed to disappointment would say?
Not for me, personally.
Without wanting to rehash this thread ... https://singletrackworld.com/forum/topic/giving-up-the-fs/
For the riding I do, 99% of the time, a good, modern (and, even better, 29er, Ti, and possibly semi-chubby) HT is enough for me. And PX/OO are likely to be able to do that at a price I can (save up to) afford ...
Posted : 03/05/2019 3:42 pm
I wish you luck! Or at least more than I've had where "one bike for everything" has always been a prelude to another bike in 6 months' time. My wife otoh has one (hardtail) bike for everything and enjoys it but has no idea why I might want a road bike and a mtb and... Well she has a very good idea actually and it's that I just want another bike. But she's wrong...
Posted : 03/05/2019 3:51 pm
“one bike for everything”
It's not quite that. I have a gravel bike (with a second set of road wheels) and a commuter hack (which only gets used on really mucky days, or when taken somewhere a bit dodgy and might get pinched)
But a "one-MTB", I've done before, for years, and been largely happy with that.
Posted : 03/05/2019 4:11 pm
I think I just like shinny things...
(mods please delete this post. My wife must not see that)
Posted : 03/05/2019 4:26 pm
One bike is very appealing from a maintenance point of view. Massive PIA maintaining a few bikes, they all always need something doing, despite them all getting used less individually.
Posted : 03/05/2019 4:32 pm
Does anyone know what will happen to the DeeDar frame? If they stop making them will they be reduced and sold off or will it disappear over night?
Posted : 06/05/2019 6:43 pm
Currently on clearance at £179.99 with a new longer boost model coming.
Posted : 06/05/2019 7:37 pm
Fine timing, thank you good sir.
Posted : 06/05/2019 10:05 pm
Brant will any of these be sliding drops/ebb so can be run ss as well?
Posted : 07/05/2019 7:41 am
Is SS still a thing?
Some sliding drop stuff tho yes.
Posted : 07/05/2019 7:50 am
I'm being lazy and not reading back through everything but will there be a steel gravely type frame with some decent tyre clearance, SS sliding dropuuts maybe?
Something like a Cdf/day one that you could squeeze a 2" tyre into...
Posted : 07/05/2019 8:33 am
Any clues to what frame from the list will have sliding drop outs?
Posted : 07/05/2019 9:37 am
I'm considering consolidating my cross bike (Cotic X) and MTB (SS 26er Inbred) into a single bike - at the moment I do similar rides on both bikes, but each is slightly better in different ways at different points.
Currently thinking of a Bootzipper with a Geoff bar, 1x gearing and fast-rolling 2"-or-so tyres.
Posted : 07/05/2019 11:21 am
Yep.
Brill.
Posted : 07/05/2019 11:05 pm
Yes please. 69.0 HA, potentially 69.5, keep the top tube long enough for mid length stems too pls, boost and not 27.2 seat tube.
Posted : 12/05/2019 7:57 pm
Yes.
Posted : 12/05/2019 8:58 pm
Any news on an ETA for these frames?
Also any Pompetamine type frame on the way?
Posted : 01/08/2019 9:13 pm
I seem to recall mid September from another thread
Posted : 01/08/2019 10:09 pm
Page 2 / 2
