Hi guys,
Looking for that brake adapter with the marzocchi offset that was on the 2005ish 20mm forks, all I know is that it was not standard 20mm or QR spacing. Any idea where I can get one, tried searching around but no luck.
Sparx
I may not be right about this but:-
They're IS, the offset is 5mm. Older Marzocchis included a pair of 5 mm spacers with the fork.
If you use a number of washers it should have the same effect ๐ (make sure mounting bolt is long enough)
I'd second that, I recall using a pair of +5mm spacers to fit a mini onto my z150s
do you mean the spacers to move the caliper outboard? I used a bunch of washers before I tracked down the official Marz ones - you need 5mm of offset
If you mean what I think you do, there's several on CRC - it's the 20mm fork mounts that you want (can see the offset on some of the pics)
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=3883 ]like this[/url]
