Is this the right stuff, and can it be used on a carbon frame?
If not, where do I get some?
Ta
Any good off licence ..
That's IRA isn't it?
Yes, but only 70% I would assume the 30% is water. That might be ok for what you intend to use it I don't know. Amazon has some purer options
https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=isopropyl+alcohol
5ltrs of 99.9% enough?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F221251615194
Thanks, I only want to clean my bike before adding some Bike Shield to it.
I'd say go for 99%
search ebay for isopropanol. I've had from "the solvent shop" before
Ordered, thanks Simon.
Hopefully my frame won't melt.
I'd try Brian Blessed Reflection IPA
Kryton57 - MemberHopefully my frame won't melt.
Basically don't use acetone, or buy a carbon On One. Very little you have around you will hurt carbon resin and in any case often what you're looking at is a fairly typical clearcoat anyway.
Brake fluid's probably the exception, even some high quality carbon parts lack resistance to dot 4 and 5.1, raceface bars frinstance.
