tedious brake mount...
[Closed] tedious brake mount question: shimano brakes on avid 185mm post mount adapter
I'm pretty certain I've read the answer already but want to double check. Sorry if
I've just bought some Deore XT's to replace Elixr's.
I was running 185mm front with 160mm rear and have bought a new 203mm front and want to run the original 185mm disc on the rear.
My bike has post mount rear rather than IS so i was going to switch the disc and adapter over straight over (after a good clean).
Do i need washers to space out the new caliper to the correct position or will it just drop straight on?
Posted : 09/01/2013 10:58 am
I may be wrong, but the washers you use for Elixirs take into account the thickness of the calliper. This is why they are still needed when using a 160mm rotor on the front with a post mount fork. Thus, the 185 adaptor should work with all callipers to fit a 185 rotor. However, I think the sting is that the calliper and adaptor may not sit flush with each other as avid compensate for this with the tri align system. As I said I may be wrong and there is no harm trying..
Posted : 09/01/2013 11:37 am
thanks donal,
that's pretty much what i was thinking, but wanted someone to say it as well. Gonna give it a crack tonight and see how it goes
Posted : 09/01/2013 12:01 pm
