Technical support f...
[Closed] Technical support for bike build needed...please
Hi,
I have an Orange p7 frame, hope rear wheel, xt cassette and rear mech, King BB (with 2 spacers on each side) and XTR cranks with middle ring, in an attempt to make a 9 speed bike. Problem is the chain line is way off for lower gears as the chainring seems to be way over to the right, but the cranks need all the spacers on the 68mm bb shell.
Any ideas much appreciated....has anyone made a p7 successfully in to SS?
Dave
Posted : 19/08/2010 7:24 pm
Surely the BB should be 2 spacers driveside and 1 on the non driveside?
Are you SURE it's a 68mm shell?
Posted : 19/08/2010 7:29 pm
eh - 2 spacers each side? Hollowtech BB with 68mm shell use 2 spacers drive and 1 spacers non-drive:
http://www.parktool.com/repair/readhowto.asp?id=95
Posted : 19/08/2010 7:31 pm
just pop one of the spacers off drive side and if loose withoutit then whip it on the left should be ok without tho.
Posted : 19/08/2010 7:32 pm
is odd. have tried with three spacers and the xtr won't tighten all the way. They are not hollowtech 2, but like race face with a big tensioning bolt. don't know which year
Posted : 19/08/2010 7:43 pm
the newer XTR's have a separate collar on the non-crank side which you use to take up the slack - is this wound into the crank before you fit it?
Posted : 19/08/2010 7:45 pm
no, i've tried that and it's not the problem. It seems that the chainring is just too far over. maybe i'll have to try different cranks
Posted : 19/08/2010 7:51 pm
def 68mm BB?
Website says yes ๐Ÿ™‚ I got no other thoughts ๐Ÿ™
Posted : 19/08/2010 7:53 pm
Sounds stupid - but the middle ring is actually on the inside of the spider, and not the outside(where the outer should be)?
Posted : 19/08/2010 7:54 pm
When I first fitted my 2007 XTR chainset I found in needed a little encouragement to fully locate into the drive side bearing. Took me a 20 mile ride to find this out!
Posted : 19/08/2010 7:56 pm
think middle ring is on inside but will check. might try and 'bed in' the cranks. thanks everyone
Posted : 19/08/2010 8:08 pm
Later, at Dave's house...
Posted : 19/08/2010 8:10 pm
Just a thought, but when you say the 'chain line is off' what exactly do you mean?
The chain line on my 853 Inbred is 'off' too: As in the chain isn't straight in the middle ring and middle sprocket.... But it still works.
It's the 50mm chain line standard and lots of mud room that does it I think. They might "all be like that, sir"
๐Ÿ™‚
Posted : 19/08/2010 8:14 pm
Think you might be right. The chain is dragged off the chainring on the largest sprocket so do i need a device at the front to keep it on?
Posted : 19/08/2010 8:26 pm
i was in the same predicament, someone told me to try it without any spacers and it worked just fine and still is after 4 months, just set my wifes bike up like it too, but she needed one spacer on the non drive side to keep the crank arms the same distance the same each side from the frame. don't think this is 'correct' but it works all the same
Posted : 19/08/2010 8:31 pm
the chainset axle sticks out miles if you try that - it really needs those spacers
Posted : 19/08/2010 8:36 pm
 5lab
http://www.chainreactioncycles.com/Models.aspx?ModelID=11937
can't reccomend one strongly enough
Posted : 19/08/2010 8:38 pm
mine was fine, just thought i would share my experience hoping it might work for you. hope you sort it out soon ๐Ÿ™‚
Posted : 19/08/2010 8:44 pm
 br
Also important is how near the ring is to the chain stay.
Posted : 19/08/2010 8:53 pm
cheers everyone
Posted : 20/08/2010 7:57 am
