Technical RS Revela...
[Closed] Technical RS Revelation query (2012 vs 2013 internals)
5 Users
I've got some 2012 Revelation RCT3s. If I was to buy some 2013 Revelations (Cheap ones, E.g. the Rev RL), can I simply drop the RCT3 cartridge in the new forks and have the benefit of better damping in a new chassis? Are there any downsides to this idea?
Posted : 03/05/2013 5:51 pm
NO one knows?
Posted : 04/05/2013 4:00 pm
LOCO
Posted : 04/05/2013 4:44 pm
not sure but i think they have not changed chassis 2012/2013. damper prob just screws in, adjust oil level and good to go?
Posted : 04/05/2013 6:35 pm
Why bother with the hassle though if they've not really changed?
Posted : 04/05/2013 6:37 pm
as above, why? they have not changed.
But yes the the dampers should be interchangeable but the RCT3 is not actually a better damper. Its the same system but just adds the open - threshold - lockout dial. the damping is the same so unless you use the RCT3 lever you won't notice any difference.
Posted : 04/05/2013 10:27 pm
I want to change the steerer tube (it's too short for new frame) and itll be cheaper to buy new forks, swap the uppers and sell a hybrid fork, than to buy new uppers at £180.
The RCT3 damper has adjustable low speed compression which the other dampers don't have.
Posted : 05/05/2013 3:01 am
