Tech help. Raceface...
[Closed] Tech help. Raceface Cinch problem.
Hi guys, can anyone help with a weird problem?
Got a mates bike I've helped him change the bb with. It's a raceface cinch system.
Its a 73bb threaded bb shell so we've put one 2.5mm spacer on the drive side cup.
When the drive side 8mm bolt is up tight there is still a fair gap on the non drive side.
You are supposed to wind the side tension thingmybob up to preload the bearing laterally but when you do it screws off the end of the threads because of the gap, before you get it to bite up.
I've thought we could add a spacer on the non drive side cup but will that mean the internal sleeve let's muck into the system from and water that's increased in the frame?
Anyone found similar and got a good solution?
Posted : 13/08/2017 7:35 am
What bike & bb is it on? Are the cranks original with the bike?
Posted : 13/08/2017 7:52 am
Cotic Soul.
The previous bb didn't have the same issue, it's like the new bb is very slightly narrower
Posted : 13/08/2017 8:14 am
Have you used the same bottom bracket?
If you don't use a rf one I think you need spacers.
Posted : 13/08/2017 8:41 am
Yes it's the same bb aledgidely.
I'm try a spacer on the non driveside cup and see what happens.
Posted : 13/08/2017 8:48 am
I had a weird issue on my Aeffect cinch cranks with Hope BB on a recent install, had a gap like you mention and the only way I could eliminate it AND have the crank arms line up correctly was to install 2 spacers, both on the drive side BB cup.
Plus, on Aeffect cranks at least, there are, or should be several non-drive side axle thin elastomer spacers which can be prised off/added as needed. It seems that they take up the final slack. Aeffect also uses a weird approx 8mm spacer on the drive side axle - not sure if your crank would require these though?
Posted : 13/08/2017 9:33 am
My Hope bb with 6c cranks is similar. I just put a wheels manufacturing 1mm x 30mm spacer each side.
Posted : 13/08/2017 11:17 am
Just covering all possibilities, you've still got the washer/ seal on the drive side of the crank?
Posted : 13/08/2017 12:22 pm
Yes the seal is present on both sides.
Posted : 13/08/2017 1:41 pm
Where do I get some of these?
Posted : 13/08/2017 1:42 pm
Crc do a hope 1mm spacer, I use one for my sixc/hope bb setup
Edit - here... it's an unimpressive item for two quid
http://www.chainreactioncycles.com/mobile/ie/en/hope-bottom-bracket-spacer/rp-prod36416
Posted : 13/08/2017 1:45 pm
Not sure if [url= http://www.raceface.com/media/BBchart-x2.pdf ]this[/url] helps.
Posted : 13/08/2017 10:04 pm
I had similar issue and luckily had a 30mm spacer from an old BB that sorted it.
Remember the CRC ones above go behind the BB cup rather than on the outside on the axle itself.
I used a 30mm ID one as I wanted the BB cups to be fully into the pressfit shell as mechanically that is a better solution in my eyes.
Hope that makes sense? ๐Ÿ™‚
Posted : 13/08/2017 10:11 pm
The red spacer is what I used.
Posted : 13/08/2017 10:17 pm
