Any stock? Enough interest for a group re-order?
I'm quite keen on a 35T in black.
Keenness here too, but prob of the 34 tooth variety...
Can't say I'm not curious, would depend on price
Is interested, just been looking at the Goldtech ones.
Unsure what size mind, currently on a 32t..
come [i]on[/i] Al, I've a sweepstake to win ...
Maybe a 34 for me, got a 33 already but need another for a different project but will depend on price as not desperate.
yeah - currently on 32
Goldtech ones.
they are the tazzy wibbly wobbly rings. They have a good stock at the moment, uno compatible ones as well. all sizes from 33-36. Listen to you unkle tazzy this is the important bit. GO up at least 2T on your normal SS ratio, it's the magic number.
you can contact Kev direct or if enough folks are interested let me know and I'll go and do some bartering for a group deal.
OK I'm in for a 34 then, should I go to 35? (eeeek!) ps as long as they fit on SLX
mattjg on what bike? 34 or 35:19 is wicked on a 29er
scaredy- who's money is on me waiting till they're all on the classifieds? 😉
Ballpark price? Would be after 34 Uno
lolz will you [u]Actually[/u] try one then Al? 😛
@tazzy 29er currently running 32:18
Well OK, if there's any sort of group thing going on sign me up for a 34, why not?
Ok it's been a long week and I'm tired so stupid question just to be sure......for front clearance issues I need to stay at 32 front and therefore I drop two teeth on the back?
34 will be sweet, then mate
(no issue going to 19 on the back if it helps - the 18 is getting worn anyway)
Al - I'm in awe! When did you actually get yourself a title other than just a member?
33 is the smallest wonky ring they do.
tazzymtb - Member
lolz will you Actually try one then Al?
Maybe, for reasonable money. I'm curious, have I ever said anything against them?
Rickos, what can I say, I earned it 😎
I need a new 33 UNO ring .......so is there going to be a group buy ???
with pounds/cash/money donation to the powers that be 😉I earned it
I paid for it AND earned it 😎
@Gotama this is for your Swift? (If it won't fit on yours I guess it won't fit mine). What cranks do you have?
I'd be interested in a 34 🙂
they fit on a swift no problems
had a 33T, sold it
I gUeSs ThIs ThReAdS's NoT fOr YoU tHeN.
If the price isn't terrifying I'll have a 33T 104BCD one please.
Any idea on the price?
Will the one they describe as Shimano Centrelock fit a Middleburn crank?
Thanks
Mattjg - no for the yelli. It's ridiculously close to the chainstay with a 32 mounted on the inside of the spider. I could shift it to the outside and the move the sprocket at the back across but, rightly or wrongly, I have it in my head that the further out you run the rear the more pressure it puts on the pawl springs.. Might try a 34 and if it doesn't fit I'll stick it on the swift as I am oval curious.
Mine fit a swift with deore HTII cranks no probs
I don't think anyone is contesting whether they fit a swift.
How would this work on a sniggle speed full sus? Would counteract any bob or make it doubly bad?
What are they?! 😕
elliptical ring for singlespeeds njee20, means you can run a bigger gear and get over grunty stall points on steep climbs. May work on 1 x 10 etc but never tried it with that.
How come they didn't work back in the day but they do now ? Snakes piss 😉
Is there one for the old XTR spline type cranks? The 33 Jericho Suffering on mine has very pointy teeth and is beginning to scare me... I wee ride on Taz's ring is temping me.
firestarter - Member
Different orientation - and jury out on "works now".
yep wiggo used elliptical rings cos they are gash 😀
and ned overned
and the niner ergon mtb folks
and the specialised factory xc team
and the garnim team
and carlos sastre
and some single speed giffers 😀
Gotama - MemberI don't think anyone is contesting whether they fit a swift.
whatever you say chap 😆
and jury out on "works now".yep wiggo used elliptical rings cos they are gash
He said jury's out, not they're gash. If they definitely worked then every single rider in the peloton would use them, plus SRAM and Shimano would make them!
I'm interested to try them (elliptical rings generally). Doubt you do 88mm BCD anyway though? And I already run a 36t, so it's not looking good!
have a chat to the goldtec chaps, they can cnc all sorts of variations. They have made a dinner plate 60 odd tooth elliptical for a track bike for some record attempt thingy wotsit.
My mate uses rotor cranks on his road bike, he can't decide for or against them
I like the idea of having two free teeth on the crank 😉
Tazzy, count me in, I'll have one.
Currently 32:17 and have a 19 for spinney climbing stuff so guessing a 34t based on what you've said so far. Using Sram XO cranks.
When will know you've got them or should we go direct??
Cheers.
I've been running one for about a year & really like it. They last very well. They make the singlespeed pedal stroke smoother & I certainly didnt notice the 1 tooth increase I went with.
Tazzy...just out of intrest, do you think they would work if I ran two as a dingle speed ?
[url= http://farm8.staticflickr.com/7056/6928674149_84b6988920_z.jp g" target="_blank">http://farm8.staticflickr.com/7056/6928674149_84b6988920_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/6928674149/ ]IMAG0335[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Taz up for 2 please - currently running 32 so guessing I'll need 34
Humm interested, up one tooth, up two teeth, I hate these decisions 🙄
Ball park cost of 104 bcd 33T/34T
Im slightly confused by the +2t idea. A normal 4 arm crank the smallest you can (easilly) fit is a 32t, so the max leverage ratio any oval ring could have would be same as the 32 (ie. point of chain contact from centre of axle)? Does that mean that you choose a 34t oval ring as it would have more speed but same power/ability to climb as the 32?
Thoughts?
Ta.
Also, do they work with 9speed chain?
righty ho folks, I'll have a chat to the goldtec boys and see what best price we can sort for a group buy. It may be easier if I can just get a code from the boys and email it to the interested parties and you can deal direct with your discount.
Last time I organised it I was a total dobber and forget to get the postage cost off folks so ended up out of pocket, but with a warm glow of spreading the wonky love. I'm a bit special like that! 😕
Tazzy, no problems, will sort it either way to suit you no problems 😀
Thanks for the update and the thread, came just at the right time for me this..
Muchos Grazias
I'll be in if the Shimano Centrelock version will fit my Middleburn cranks...
they do direct mount uno version for middleburn, or the normal ones work with the standard 4 arm 104 bcd middleburn spider.
tazzymtb - Member
Thanks - is that the one they describe as centrelock [url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=440&Name=Goldtec+OneKey+Rings ]here[/url]? Bought the vranks this week second hand and still making sure I understand what I need 🙂
looks like middleburn direct mount version. i'll check tomorrow for you.
Thanks - appreciate it.
Loving my 35t Tazzy, may need to get a 33t one next.
Cheers Tazzy!
Right folks. From friday the 18th until the 25th the wonky rings will be available on the betd goldtec website for a discounted price with free postage as well, so order direct and have fun.if you want the tazzy guide to set up email me as there are a couple of cheeky tricks to get perfect chain tension. Cheers.
Good work! Thank you!
Could you put your email in your profile? It's worked out well so far, cos I wouldn't have started this thread if it had been in there!
Or send me set up to the address in mine.
Cheers again,
Ed
Thanks!
Thanks tazzy, will give one a try. As above could you pop your email in your profile or drop me an email (address in mine) with the set up....or post the technique in this thread. Ta
tazzymtb - Member
Any idea how we get the discount? They're still showing as the same price
Muchos Tazzy.
I'll need the setup as I'm using Niners EBB.
Also interested in one of these - was just going to buy one direct, but I see they've put the price up now, so would be interested in how to do the group buy thing - I'd mail tazzy if I knew what his mail was...?
Me too. Almost certain they were £35 when this thread started.
is it these?
ready to hit the button when the price drops ...
Tazzy could you put your tips on a blog and link them, (unless you have a reason to keep them private)? Posterous takes moments to set up if you need a publishing tool, or I can do it for you.
Yep, they're the ones.
Price is showing as £34.99. Are we expecting it to go down from that? It seems to have gone up then down to the price it was before...
I'm confusticated 😕
@cheez it was defo showing 45 quid a couple of hours ago.
Bikebouy...mine is on a SIR.9.
I set the tension with the cranks as in my pic.
Anyone tried these on a 1x10 setup?
[url= http://chris-noble-mtb.blogspot.co.uk ]http://chris-noble-mtb.blogspot.co.uk[/url]
The CRC school of product discounting.
And for that reason I'm ooooot....
Yeah, does seem that someone was trying to be a bit clever there. Ah well, happy paying 35 quid for the ring so i'll give one a try.
The rings are 45 quid. Their it gimp fluffed up when he put them on a few weeks ago. Hence the return to normal price before dropping to the discount for the next week.
Anyone know if a 36T will fit on a Swift?
yes in the outer ring position, if using standard cranks. With an uno it'll be tight and the EBB will have limited movement (be at the front as it were)
Thanks - I'll go with a 34 in that case I think. Can always put a smaller freewheel if I need to.
