Hi,
My bike blew over in the wind today and now the gears are slightly out of sync (Di2). I suspect the mech hanger is bent.
Its a 2019 Tarmac Pro Disc Sl6.
Does anyone know what mech hanger I'll need for this? I've Googled it but have different suggestions, etc.....
Many thanks, Ben.
Which one of these is it basically:
https://www.mountainbikecomponents.co.uk/product-category/derailleur-hangers/specialized/?bike_type=road
Either get a hanger tool
Or get it aligned.
Even if you get a new hanger it’s best to check it with tool anyway
Managed to use an adjustable spanner to pull it out ever so slightly. Put the mech back on and went through the gears.
Seems to be running fine but will be ordering a new one just to be on the safe side.
Cheers guys.
I knocked my Roubaix over last week and just stood it back up. I went out the following day and almost put the rear mech through the back wheel. After rining around no one had a rear hanger in stock and have to order an official one which will take over a week.
But I did find a Pilo copy on Wiggle which I ordered and works fine.
You’d be better off getting the original one realigned as it can probably be saved, the 1st thing you should also do to a new hanger is align it as they’re rarely straight out of the packet.
I build loads of bikes from new - quite a lot need the hangers aligned out the box, particularly 11 or 12 speed to get the gears to shift smoothly.
Yep, it’s been said before, buy an alignment tool, worth every penny.
