Tapping rack thread...
Tapping rack threads in On One Scandal
6 Users
Hi all,
I am wondering whether anyone might have modified their On One Scandal frame by tapping threads in the dropouts.
I would like to be able to fit a rack to it for childseat and trailer towing. Seems like there is enough space in the dropout to do it but could be a horrible idea.
I have already slid down some rocks on the bike so battered the paintwork so resale value is not too much of an issue for me.
I would handle the upper ones using a seatclamp I have with threads on.
Posted : 31/07/2023 4:29 am
I saw a scandal for Sale on Facebook a few months ago with this done but they didn't make mention of it. There's definitely enough space there to do it, I'm just not sure it's designed for it. Planet x sell steel versions with rack mounts.
I think if your doing it for bike packing, you could get away with it but I wouldn't risk it I for something like the badger divide where of it fails your left in the middle of no where. I also wouldn't trust it for a child seat.
I'm currently using a Robert axle project axle and old man mountain rack, mounted to the axle and a seat post clamp. Works really well but the rack is on the heavy side.
If you do tap the frame, please come back and post some pictures. Good luck
Posted : 31/07/2023 8:51 am
If the drop outs are simply big chunks of alloy, then there’s no reason why not - drop out threads are usually M5 x 0.8, so 4.2mm diameter hole
Posted : 31/07/2023 8:56 am
 Sven
Not into the drop-outs, but into the seat stays, once at the top and 2 holes lower down along the seat stays, and even that held up...
On-one scandal seatstays
I even drilled holes into the top tube for poor men's internal cable routing, and shortly after Brant was sitting at the table next to mine in a pub, and he said: holes in the TOP tube, that's fine...
Sven
Posted : 31/07/2023 12:37 pm
Op, which version of the scandal? V1, v2 or v3 (the current one on sale?)
Posted : 31/07/2023 5:34 pm
This would be into a V3 (current Scandal). Seems like some mixed opinions on whether this is a reasonable idea or not. I tend to think as someone said that it is quite a big chunk of aluminium. I also don't think the resale of the frame is meaningful espcially as I am currently living in New Zealand where I suspect On One brand appeal is niche.
P clips are less of an intervention but actually feel like a bigger frame damage risk to me with 18Kg child on top.
The Robert Axle is a nice solution but rather spendy and not that easy to get hold of I suspect.
Hmmm....
Posted : 30/08/2023 5:33 am
Tubus do fixing kits for bikes without mounts.  Axle mounts induced.  If there is a decent amount of flat metal at the dropouts I would have no issue drilling and tapping tho
https://www.tubus.com/en/products/
Posted : 30/08/2023 9:12 am
