TALAS, FLOAT OR VAN
[Closed] TALAS, FLOAT OR VAN
Im in the market for some 36, 160mm forks and cant make my mind up. Its to go on a Nicolai am. I ride alot of trail centres but i also do some local more gentler riding, any help or ideas???
Posted : 02/01/2010 5:21 pm
well the vanilla's are by far the smoothest if that helps.
Posted : 02/01/2010 5:24 pm
Float 36's on My Nicolai FR.... Very nice without the weight.
Posted : 02/01/2010 5:30 pm
I've got 36 van's on both my xc bikes. I had TALAS before but didn't use the travel adjust feature so changed them.
Think carefully if you want travel adjust, if you'll use it, when etc and take it from there. If the answers no van's are nicest, try to get the rc2 versions as the damping cartridges are more reliable.
Posted : 02/01/2010 5:31 pm
I've had all forks and prefer the Vanillas for performance, but only just as the Talas and Float 2009 onwards are great. I have a set of 2009 Talas for Sale now as the steerer is just too short for my new Uzzi.
Posted : 02/01/2010 5:43 pm
 goog
I got some 09 36 TALAS on my Remedy and can't grumble.
Posted : 02/01/2010 5:50 pm
I find I don't really use the U-Turn on my RS forks, but I used TALAS loads when I had a set. It's just so easy and simple to use it was worthwhile doing.
Posted : 02/01/2010 6:10 pm
 thv3
As above, Vans are definately the most supple.
As for the weight penalty, it's not worth compromising on unless you are a weight weenie.(Less than 200g)
Posted : 02/01/2010 6:37 pm
Im getting the feeling it might be worth having a play with the Vans
Posted : 02/01/2010 6:47 pm
