tacx sirus turbo pr...
[Closed] tacx sirus turbo problem
2 Users
havent used it for a few weeks and now the resistance doesnt seem to increase as you move the lever
Any ideas?
Posted : 15/05/2011 7:52 pm
is it stuck in hard or easy?
IIRC the magnets can be pulled up too high and then not drop down so it is easy all the time
If too hard some sort of cable /jamming or mabnets jamming issue
take the cover off turbo and have a look- carefully but not a hard fix but a bit fiddly
Posted : 15/05/2011 7:57 pm
easy, no matter what its set at
Posted : 15/05/2011 8:01 pm
then the magnets has been oulled clear of the flywheel
cable pulled it to far now it is stuck up or it has jammed on something??
either way you are goin gto have to take it apart to see
Posted : 15/05/2011 11:19 pm
