TA Rings - Best Pla...
[Closed] TA Rings - Best Place To Buy or In Stock?
As above really, cheers
Posted : 31/07/2010 6:11 pm
Thanks for link, but after 28inner and 40outer to make 2 ring set-up.
Posted : 31/07/2010 7:38 pm
SJS cycles normally have good stock.
You want a 40T middle for a two ring set up not an outer, you mount it in the middle ring position with short chain ring bolts, just checked SJS and they have what you need.
Posted : 31/07/2010 8:01 pm
 gee
Hi
I bought that combo from that German place - Starbike I think. that was 3 months ago and no-where in the UK (including Chickens) had any in stock.
GB
Posted : 31/07/2010 8:10 pm
Thanks guys, will go and check now.
Posted : 31/07/2010 8:16 pm
I thought the larger chain ring was an outer but located in the middle position?
Don't you need the shift pins etc of the outer chain ring?
Posted : 31/07/2010 8:49 pm
Clee Cycles..
Got mine this week and a nice set of Kcnc Bolts ๐Ÿ™‚
40/28 in stock and they look awesome.
Posted : 31/07/2010 8:56 pm
Got to be middle as no 40 outers!! Doh!
Posted : 31/07/2010 9:02 pm
ordered from Clee, cheers guys
Posted : 31/07/2010 9:16 pm
Hi Hornet600, Mike from Elmys. If you're going for XTR M970 cranks you'll need 4xM8 spacers, 2mm wide. Check out [url= http://www.tastynuts.com/Products/Aluminium_Washers_Drilled_Individual ]Pro Bolts[/url].
Posted : 01/08/2010 8:41 pm
Cheers Mike
Posted : 02/08/2010 4:32 pm
