Swapping norglide b...
[Closed] Swapping norglide bushes to du bushes on a rear swing arm?
Hi guys,
I have installed new du bushes into the linkage of my saracen ariel. The reason being that i was getting excessive flex from the rear end and the edges of the norglides looked chewed up. The bushes have been sourced through a relative in engineering and they are a match of what was on there. Can you see there being any problems with this?
Regards
Posted : 10/09/2013 12:11 am
 nonk
Nope.
Posted : 10/09/2013 12:57 am
The "top hats" are worn hence the wear....
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=92&Name=Strong+Bushes ]Replace your "top hats" and bushes with this kit assuming it has top hats? [/url]
Posted : 10/09/2013 1:37 am
Are the top hats on that link du bushes anyway? When i say worn i mean that the they were not on the bike that long. They had no vertical movement but I could move the back end laterally and I thought a bit of this could be attributed to the rough endges that looked a bit worn.
They are not going onto the shock just the frame linkage. Could someone please explain to me why these would not work?
Posted : 10/09/2013 10:34 am
My Experience of DU bushes in suspension linkages, is that they do not last long
Think of them as a service item.
But if the originals are supposed to be a top hat then a std DU bush will not be sufficient as you will not have a thrust surface
Posted : 10/09/2013 11:12 am
Hi Tom. Can you drop me a line please regarding your Saracen?
mark.pearson AT madison.co.uk
Posted : 12/09/2013 12:19 pm
tom13, how are you getting on with the du bushes? have you found out any new info?
Posted : 09/10/2013 4:02 am
