Swap external/conve...
[Closed] Swap external/conventional headset for integrated?
Is it possible as I've swapped the forks from 130 to 140 and I'd like to lower the front end by killing the 1cm of the headset which sits between the fork and frame?
The headset says its a Feimin FP-H856E for 44mm ID - the bike is a pinnacle ramin 2
Thanks
Posted : 12/05/2020 11:13 pm
Straight steerer on the forks, then yes, tapered steerer, no.
No need though. You won't notice the difference
Posted : 12/05/2020 11:17 pm
Like nickjb has said with a 44mm head tube the only was to run tapered forks is with an external cup bottom headset. If you are lucky and happen to have a straight steerer With crown reducer then all you have to do is swap your current ec44 bottom headset for a zs44 bottom headset.
Posted : 12/05/2020 11:44 pm
Thanks both. I assume there aren't any lower profile external ones available as a compromise?
Posted : 14/05/2020 11:24 pm
A couple of mm maybe but really, it won't make any difference.
Posted : 14/05/2020 11:37 pm
