Superstar Switch Ul...
[Closed] Superstar Switch Ultra Front Hub Bearings?
As in the title, I can find Switch Evo front hub bearings but not specifically Switch Ultra. Does anyone know the proper bearing spec, please, or would anyone please be kind enough to stick a link up for me?
Loads of Blue Seal ones on ebay, could just do without the arse of ordering wrong if anyone cam help.
Much appreciated if someone can, ta.
Posted : 10/06/2021 12:34 am
 poah
@poah
Brilliant - cheers.
Posted : 10/06/2021 8:40 am
Thanks again to poah for the help bearings swapped out this evening.
No thanks to whoever designed the hubs with the stupid spacer through the middle of the hub that only squeezes over to the side by 0.5mm and tries to spring back (it is held in place by o rings hence the springiness). I seriously considered not putting it back in as I can't see that it does much good, but I put it back in for 'completeness'.
Posted : 11/06/2021 10:27 pm
