Superstar sintered ...
[Closed] Superstar sintered pads - any good with Martas?
6 Users
 bol
Seduced by the apparent excellent value of Superstar's multi-buys. Anyone used them with Magura Marta SLs, and if so, were they any good?
Posted : 27/11/2010 2:36 pm
 bol
Anyone?
Posted : 27/11/2010 9:53 pm
They ought to be alright, they work okay in other brakes. Okay so they're missing some feedack to tell you they're actually biting the rotor, they can squeal and will build up a bit of heat, but they do last (or mine do) in (mostly peak grit) slop, and especially for the money, they're very good just for that
They will void you Magura warranty though, being sintered I believe
Posted : 27/11/2010 10:20 pm
Ive only ever used them with Avids... there OK but my god do they Sqeeel.... and yes Ive tried every thing to remedy the problem.. I personally prefer there Kevlar pads, but they don't last as long as the sintered...
Posted : 28/11/2010 6:17 pm
Hi Bol,
Don't do it... Sintered pads build up heat too much and don't shield the caliper enough. Normal Kevlar pads have enough heat dissipation in the pad body to avoid the brake getting cooked. If you want a pad that lasts longer try a harder Kevlar compound pad. And this is apart from the fact that sintered pads squeal louder than any other type. 😯
Posted : 29/11/2010 9:21 am
 Joe
I've been using them for ages on my Marta SL's. Absolutely fine, no problems at all, ample power, recommended.
Can't say i've noticed any squealing unless its really wet and gloopy.
Posted : 29/11/2010 9:31 am
Been using the superstar kevlar race pads since the summer now on my Martas, they have been excellent. Recently developed a problem with one of the master cylinders though so opted for a new set of Elixir CR's. Therefore I have a few pair going spare if you fancy a bargain, 2 pairs in unopened packaging for £10 posted. let me know.
Posted : 29/11/2010 11:04 am
 bol
Thanks guys. Sounds like Kevlar is a good bet then. CrombieCraig, mail heading your way.
Posted : 30/11/2010 8:26 pm
