One of the clamp thread has stripped just looking if anyone has one in the garage spares??? Tia [img] http://s350.photobucket.com/user/swainmatthew26/media/C2C91CBB-7FC5-4003-974D-DE89150574C7_zpspmjvlcu0.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/C2C91CBB-7FC5-4003-974D-DE89150574C7_zpspmjvlcu0.jp g" target="_blank">http://s350.photobucket.com/user/swainmatthew26/media/C2C91CBB-7FC5-4003-974D-DE89150574C7_zpspmjvlcu0.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/C2C91CBB-7FC5-4003-974D-DE89150574C7_zpspmjvlcu0.jp g"/> [/IMG][/URL][/img]
[img] http://s350.photobucket.com/user/swainmatthew26/media/9CE0A86C-8311-4D4A-A928-B3027F77E2CE_zpskwfn7npo.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/9CE0A86C-8311-4D4A-A928-B3027F77E2CE_zpskwfn7npo.jp g" target="_blank">http://s350.photobucket.com/user/swainmatthew26/media/9CE0A86C-8311-4D4A-A928-B3027F77E2CE_zpskwfn7npo.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/9CE0A86C-8311-4D4A-A928-B3027F77E2CE_zpskwfn7npo.jp g"/> [/IMG][/URL][/img]
[img] http://s350.photobucket.com/user/swainmatthew26/media/18EAA9FF-4EA8-4E7B-9F3A-F9333C9E398A_zps1ltdvymy.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/18EAA9FF-4EA8-4E7B-9F3A-F9333C9E398A_zps1ltdvymy.jp g" target="_blank">http://s350.photobucket.com/user/swainmatthew26/media/18EAA9FF-4EA8-4E7B-9F3A-F9333C9E398A_zps1ltdvymy.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/18EAA9FF-4EA8-4E7B-9F3A-F9333C9E398A_zps1ltdvymy.jp g"/> [/IMG][/URL][/img]
Yes, I've got two.
One is a bit chewed up on the outside because I had to use mole grips to get the bastard off of the axle. I can let you have the axle (it's a stronger steel version) too.
The other is still connected to half a snapped axle - I can't get the sodding thing off, but you would be able to cut a slot in the axle and use mole grips on that too.
Just a word of warning, the stock alloy axles are poor - I've snapped two, so the steel one is a good upgrade.
I've totally knackered my hub anyway and invested in Hope now I've been burned, so you're welcome to whatever bits you want. You wouldn't want the pawls or the ratchet, though, as they are basically swarf.
Give me a shout if you are interested.
Oh bugger, just noticed yours is thru-axle.
Mine are qr. Give us a shout if you want the bits.....
Sorry mate you’ve confused me a little. The axel is out of the rear hub and is the steel version however my front axel is ally like you say. The rear hub is a 9mm qr axel is it worth me taking a photo of my whole assembly just to see if it replicates what you have? Cheers
Might be worth a photo!
All my bits are for 9mm qr rear axles. As the fixed end of the axle is 9mm qr specific, there is no cross-compatibility like Hope.
Sent you a pm mate and will get photos in 5 mins
[img] http://s350.photobucket.com/user/swainmatthew26/media/918DCD0A-9D0C-495B-BD14-83AC7D318057_zpsojfjeolu.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/918DCD0A-9D0C-495B-BD14-83AC7D318057_zpsojfjeolu.jp g" target="_blank">http://s350.photobucket.com/user/swainmatthew26/media/918DCD0A-9D0C-495B-BD14-83AC7D318057_zpsojfjeolu.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/918DCD0A-9D0C-495B-BD14-83AC7D318057_zpsojfjeolu.jp g"/> [/IMG][/URL][/img]
[img] http://s350.photobucket.com/user/swainmatthew26/media/DA834BF7-0462-4A8C-9A33-B1FEED6FBC61_zpsgejnfr9e.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/DA834BF7-0462-4A8C-9A33-B1FEED6FBC61_zpsgejnfr9e.jp g" target="_blank">http://s350.photobucket.com/user/swainmatthew26/media/DA834BF7-0462-4A8C-9A33-B1FEED6FBC61_zpsgejnfr9e.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/DA834BF7-0462-4A8C-9A33-B1FEED6FBC61_zpsgejnfr9e.jp g"/> [/IMG][/URL][/img]
[img] http://s350.photobucket.com/user/swainmatthew26/media/0019FEB4-46EF-4E27-BD41-A7820D4553B8_zpsjl77cri5.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/0019FEB4-46EF-4E27-BD41-A7820D4553B8_zpsjl77cri5.jp g" target="_blank">http://s350.photobucket.com/user/swainmatthew26/media/0019FEB4-46EF-4E27-BD41-A7820D4553B8_zpsjl77cri5.jpg.html ][IMG] http://i350.photobucket.com/albums/q402/swainmatthew26/0019FEB4-46EF-4E27-BD41-A7820D4553B8_zpsjl77cri5.jp g"/> [/IMG][/URL][/img]
It’s just the threaded clamp on the right that I need that the thread has stripped. You’ll be a massive help if you have one fingers crossed
The end piece that I am after is the same though isn’t it. Does it have the flats to tighten using acone spanner?
I don't think it is the same because it has a capped end with just enough room for a QR skewer. Yours are fully open by the look of it - to accommodate the wider axle(?)
