Superstar Delta, du...
[Closed] Superstar Delta, durability?
7 Users
Hi chaps,
The Deltas have been out a while now, how are people finding the durability? Do they spin very fast, or are the seals still tight?
Ricks
Posted : 23/12/2015 9:04 pm
I have a set of the delta evo mag ti pedals. They lasted approx 400 miles of off road riding before the drive side pedal bearings failed.
So,not brilliant longevity.
You can buy a rebuild kit for them, but you need a socket with such thin sidewalls, I dont think such a thing exists.
So I gave up and bought some raceface atlas pedals
Posted : 23/12/2015 9:24 pm
I had a pair with titanium axels and they sheared off the axle half way round Ae and I had to limp the remaining way round and buy an emergency pair from a shop. I didn't really rate the grip levels either tbh.
Posted : 23/12/2015 9:50 pm
Delta mag ti's the threads stripped and the body separated from the axle half way round a night ride after a couple of hundred miles, the replacement standard deltas loosed off so the body has a couple of mm play.
Gave up and bought some hopes.
Posted : 23/12/2015 9:53 pm
Thought the hopes were supposed to 'lack grip'?
Atlas RF any good?
Posted : 23/12/2015 10:00 pm
OH has some, they did about 18 months covering two winters before a service (although they could probably have done with it sooner.
I did have to grind a socket down to fit though...
Posted : 23/12/2015 10:01 pm
@Julians you might want to consider some pre-emptive maintenance on the Atlas pedal - the right hand pedal can unwind inside causing the axle to bind. Its only a 2 min job and you're set. Email me ben@birdmtb.co.uk if you want to know what to do.
Posted : 23/12/2015 10:02 pm
The rf atlas is pretty good, very comfy and loads of grip. Cant comment on longevity yet though.
Ben - mail coming your way, thanks
Posted : 23/12/2015 10:09 pm
