Stumpjumper pivot b...
[Closed] Stumpjumper pivot bearings, do they need replacing?
[#2387658]
When do I need to change them? I've got a bit of play in the rear suspension pivots, nothing drastic mind. A mates older stumpy has much more movement in his, and he reckons there fine. Was wondering if/when they will need replacing, and how hard it will be.
Posted : 20/01/2011 3:29 pm
Mine used to ghost shift when I was hammering it if the shock bush or pivots had play in them. If there is only a little bit of play I wouldn't worry about it just keep an eye on it. If it gets worse get you suspension bearings looked at
Posted : 20/01/2011 3:33 pm
The shock pivot on my 09 Stumpy has a habbit of coming undone. Even when secure it had a bit of play in it, but after an extra hard tightening its now solid and transforms the ride
Posted : 20/01/2011 3:55 pm
If you leave the bearing to long and they fall apart they are a right pig to remove. And they are only £40 for a full set from specialized
Posted : 22/01/2011 10:15 pm
specialized bearings last 6 months normal riding as far as i can see
Posted : 22/01/2011 10:24 pm
 jhw
define normal riding - miles per week?
Posted : 23/01/2011 1:06 am
