Help needed please.
I have just purchased a 2010 stumpy HT casrbon expert frame and fox fork for my latest build and not sure what to do about choosing hubs for my wheels.
The problem is I want pro 2 hubs but the bike originally came with DT swiss 9mm RWS front ratchet and 10mm rear.
Can i just fit nomal QR hope hubs or should i get a 10mm bolt through rear and the same DT RWS ratchet that was fitted as standard and some kind of 9mm conversion up front.
Any advice would be muchly appreciated.
You can either just use bog standard QR hubs, or if you want to keep using the RWS you can convert the front to 9mm, and get the 10mm rear if you have the oversized RWS.
I do not have the oversised RWS and was originally intending to get standard QR to keep costs down as much as possible. Just want to make sure they will be OK before i order them.
