[Closed] Stumped
8 Users
Chgd big ring, chain & rear cassette on 2x10 HT.
Little ring not chgd as fine.
Gears all reset & sweet.
However, push hard on pedals in little ring & get awful creaky grinding noise. Do same in big ring no issues.
Don't understand, help pls.
Have checked the bolts on the little chain ring.
Thx in advance.
Karl.
Posted : 28/02/2017 7:35 pm
It's because the inner ring has some wear on it.
Posted : 28/02/2017 7:42 pm
So you changed all the parts apart from the little ring and it doesn't work in the little ring?
Maybe it isn't "fine" would be my guess
Posted : 28/02/2017 7:43 pm
Maybe your bike is rebelling against text talk?
(That's a joke by the way. Change your small chain ring. Cost peanuts now everyone has gone 1 x)
Posted : 28/02/2017 7:48 pm
Wee ring has some wear in it and probably needs replaced; check all the chainset bolts and make sure they are all done up b@stard tight.
Posted : 28/02/2017 9:21 pm
If it's a alloy granny ring then replace it with a steel one as the alloy ones are not up to the task, the steel ones aren't much heavier either.
Posted : 02/03/2017 6:30 am
I suspect a shortage of vowels is ur underlying prblm.
I'm concerned this even necessatates a thread:
This.
Posted : 02/03/2017 7:14 am
Take the little ring off and turn it round and try that. Because the small ring is square cut it will work either way round.
Posted : 02/03/2017 7:24 am
To complete this thread...you are all correct. Thx very much.
New chainring & problem sorted.
Didn't get to try the old one other way round but good suggestion will try it.
njee20 are you actually an a r s e or just had a bad day? BTW pay more attention to your spelling.
Posted : 08/03/2017 2:17 pm
Marvellous 🙂
Posted : 08/03/2017 2:19 pm
