Stuck FSA crank bol...
[Closed] Stuck FSA crank bolt - any suggestions?
[#6618552]
Trying to remove the cranks from my CX bike and the self-extracting bolt thingy (similar design to the truvativ ones) seems to need a lot more force than is sensible. I've managed to get it about 1.5 turns before it's just gone too tight. I've got a bit of metal tube to extend the allen key and have checked a hundred and six times that I'm turning it the right way.
Anything else I can try to get the thing shifted? It can't just be my puny arms.
Posted : 08/11/2014 5:00 pm
The bolt head can sometimes bind on the self extractor, try removing it, cleaning and greasing it, and checking the crank bolt will come out without it. Expect to use a fair amount of force when removing these cranks, they're usually pretty tight.
Posted : 08/11/2014 7:22 pm
You probably just need a bigger lever. But also try some penetrating oil? Not sure if chain oil or WD40 will work too if you don't want to buy some special oil.
I remember going to the bike shop once with what I thought was a totally stuck crank bolt. Went in, warning them that it was stuck. The guy just smiled, got out a much bigger spanner than I had and loosened the bolt without even looking like he was trying. 😳
Posted : 08/11/2014 7:25 pm
'Give me a lever long enough and a fulcrum on which to place it, and I shall move the world.'
Archimedes
Posted : 08/11/2014 7:32 pm
Archimedes may well end up with a buggered bolt if it's binding on the extractor 😀
Posted : 08/11/2014 7:55 pm
Cheers guys. Pretty much what I thought. Will give it another go in the morning after it's had some GT85 in there and if that fails the LBS can give it a pop.
Not sure what you mean by removing the self- extractor, coatsey? Surely to do that I need to remove the bolt, and that's the problem anyway?
Posted : 08/11/2014 9:20 pm
The self extractor is what the bolt presses against when you undo it, it screws into the crank arm once the bolt is fitted, I think it has a 10mm hex head on those cranks, and may possibly be a left-hand thread but not completely sure.
Posted : 08/11/2014 9:42 pm
I think what 'Coatsey' is getting at is due to the pressure from unwinding the inner bolt against the fixed outer cover the 2 bind together.
If you remove the outer normally with a pin spanner,apply a bit of grease to the inner face and reassemble then try winding out the inner bolt again you may be more successful(if thats whats causing it to stick)
Posted : 09/11/2014 8:25 pm
